Great work COPO!!
What about stronger outer spindles?
The factory 27 spline pieces
won't stand a chance against your bad boy.
What needs to happen is put a c6 zr1 bearing in there. Bolt patterns are close but due to the mold inside the knuckle make it impossible to rotate and bore new holes. Since only China c4 bearing will be available in the future something has to happen.
Originally Posted by 383tpimachine
Hey Andy this is Travis off Facebook.
If you could pm me a price on a 3.55 geared setup with a billet batwing so i can see about when i can order that would be great.
Thanks.
PMs sent to all. The billet batwing is narrower than stock. Could be changed, I would have to measure some things due to toe bar placement.
Its not cheap.
The stub axle isn't the hard part, it just cost to have made. The c6zr1 bearing is what's used in the c7 but has some ABS changes, I already have c7 suspension and bearings at the shop. Its about a 1/4 difference between the bearing 3 bolt pattern. C7 bearings are 33 spline. I'll try to get a pic for comparison with a bearing almost bolted.
