1992 C4 - Which Auto Tranny?
Old Feb 6, 2014 | 08:58 PM
Wheel Stander's Avatar
Wheel Stander
Default 1992 C4 - Which Auto Tranny?
There seems to be a lot of conflicting information on the Internet, even among folks who hold themselves out as being "experts" on Corvettes. Specifically, I haven't been able to definitely conclude whether the automatic transmission in my 92 Vette is a 700R4 or 4L60. For every article I read saying that the 4L60 was not introduced until 1993, I read another saying that GM starting using it in Corvettes beginning in 1992. So, which one should it be and how can I figure out which one I have in my car?
Old Feb 6, 2014 | 09:07 PM
WVZR-1's Avatar
WVZR-1
In the '90 FSM it's referred to as 700R4/4L60, in '91 it's only referred to as 4L60 and in the '92 FSM only as a 4L60.
I'd guess you would refer to it as a 4L60 and your concern needs to be that in '92 the ASR feature was added to the Corvette and the "on the car" adjustments are different and need to be followed. That's your primary concern.
If your concern is that the transmission is original to the car then a VIN derivative is stamped on the transmission and there would also be a data plate attached to the transmission with the ID. The transmission ID's for a '92 would depend on the axle ratio also. I'd expect one of these 2YCM for a 2.59 (GM1) rear axle, 2YDM for a 2.73 (GU2) or 3.07 (G44). I believe an AYCM or AYDM would be considered a GM SERTA replacement.
Both the 700R4 and the 4L60 carried the same RPO on the SPID label you'll find in your console. That RPO will be MD8.
Old Feb 6, 2014 | 09:42 PM
383vett's Avatar
383vett
A man of knowlege.
Old Apr 3, 2022 | 11:14 AM
RUSHTK's Avatar
RUSHTK
Default Tranny education
I would like to put in a stronger tranny in my 92. From your post I am gathering that the ASR is part of the transmission. I am not looking to race but would like a stronger one as I am increasingly upgrading my 92 convertible. Do you know if these trannys can be made stronger with the ASR? Thank you for your posts.
Old Apr 3, 2022 | 12:29 PM
WVZR-1's Avatar
WVZR-1
It isn't 'part of' the 4L60 transmission but a combination of ASR/ABS control that was introduced in '92. If you have a correct FSM you can better understand if you do reads of the 5E1 section of the FSM as well as the 7A section that covers ON-VEHICLE SERVICE.
Do you have the FSM?
Old Apr 3, 2022 | 12:38 PM
drcook's Avatar
drcook
Finalist 2020 C4 of the Year - Modified
If you do not have the FSM and you are asked something by WV, then say yes.
The 700R4/4L60/4L60E transmissions can be upgraded to hold as much HP as you realistically will be getting without major expenditures.
Read this:
https://www.sonnax.com/tech_resource...n-build-guides
Just like engine power is a direct derivative of Cubic Bucks, a strong transmission is a result of direct investment also.
Or you can look at Gear Star transmission, here in the Akron area for an upgraded trans,
https://gearstar.com/
Old Apr 3, 2022 | 01:47 PM
383vett's Avatar
383vett
Too funny!
Old Apr 3, 2022 | 03:27 PM
drcook's Avatar
drcook
Originally Posted by 383vett
Too funny!
Wasn't supposed to be funny. I was asked the same question about what I was alluding to, paid for it, downloaded it,
and use it all the time. I was just not being blatant about it. The download is just as good as my paper copy.
To 1992 C4 - Which Auto Tranny?
