Spinning to 7k
Would you need a better oil pump? Bigger oil pan?
Just for education here. Thanks!
Unfortunately theres nothing "performance" about the shortblocks sam ething they have in station wagons and trucks.
forged bottom end 4 bolt caps recommended. Those ricers have some stout blocks for their size and dont move around much. Better engineered too.
Every wannabe circle track guy is going to tell you they do 7k wtih stock stuff maybe better rod bolts those go too...and 2 bbl wonders only make about 350hp anyway.
Do it right the first time, spend the money once.
Still your 85 has oem forged pistons(trw leftovers I read somewhere) and even an old heavier style(like yours and my example) trw domed 400 piston is lighter than a stock cast dish 350. Well I'd assume a 85 forged piston is lighter and maybe someone has a weight or can weigh one. Maybe the lighter pistons would give you a little more safe rpm, how much no clue.
Tell us this: How can AFR supply a spring and make an RPM claim when they don't know cam you will be using??
Like this: "Keith (Black), I wanna a screamer that spins to 7200 RPM.
How can AFR make a specific RPM claim for springs, when they don't know what cam you are using. The fact that THAT question doesn't make you "wake up", shows how clueless you really are.
Ya claim "Ricers can do it!" which is so misguided it's unbelievable. "Ricers", have shorter stroke. Smaller pistons (lighter). Stiffer, stronger blocks that support the cranks better. There is NO comparison at all. My RC airplane motor spins 17k...so my Small Block Chevy should be able to also. See? No comparison.
Since you don't "get it"...I'll suggest what others have; go out and rip 'er to 7k and let us know how it works out for you.
Do you think that a mild cam creates as much valve velocity and force as a radical/aggressive cam? No. An aggressive cam opens a valve faster, further, and closes faster than a mild cam. SO...how can AFR (or anyone) make a universal claim about an RPM when they don't know your cam, lifters, pushrods, rockers....How can that be? They can't. All they can do is give a general estimation based on common combos. The cam grinder would know far more about the right valve spring, then the head manufacturer would.
Which is why it's laughable when you say; "AFR's website says that the springs that came with my heads can go to 6800, which is pretty close"
Better solution... buy an LT5. It'd save you a boat load of money than building a normal SBC that can handle 7k.
Unless you're beating the utter snot out of the car on a circle track that 7k mark isn't something you're going to be kissing often. Even in racing, unless you're running some pretty steep rear gears.
You'd have to reinforce the block (That stock 2 bolt main isn't going to cut it), get a better crank, pistons, rods, studs and bolts all the way around, a high rpm camshaft, pushrods, (maybe Titanium) lighter valves would be a good start too.
I'm assuming you don't have the LTR intake setup anymore either. Because if you do, you need to change that as well, because the LTR won't breathe at that RPM at all. Even with large aftermarket runners, a ported plenum, and a Ported Aftermarket Lower Intake.
I'd go More Displacement loong before I'd be shooting for 7k rpm.
7k can be fun but its hard on parts only real purpose is because the combo has to run up there and most street engines are done well before then
Mines set up to run that high and a valve lash check 2x a yr, checking springs 1x a yr or so is just part of it.
Even then something can let go wiht the best of parts
Gen1 SBC is still a cheap way to great horsepower iwth the parts we have today. Sure an LT5 can spin that high but it isnt making any power up there just heat and neat sounds btdt.
You got a nice set of heads Dan if you run a bone stock L98 to 7k you could risk popping that bottom end and damaging them.(say if a piece of piston skirt lets go and takes a walk through the combustion chamber lol)
You can do up a shorblock that will handle it for not too much no exotic stuff needed.
I run mine up to 7k once in awhile not often. Most the time honestly 6500 is plenty on the street. Many wouldnt consider it a street car with the manners it has below 3k.
There are days when I too think "shoulda gone much larger" and shot for a max of 62-6300 or so it will be funner and live much longer. One day
