Okay so I just want to find out a few things here. On an L98 bottom end, this does not include the TPI intake, is it possible to go to 7k RPMs safely with some modifications? What is needed? I have heard somethings about the rod bolts being the ones that go first, and the main cap bolts being the ones that cause the engine to shake itself apart. So I'm just wondering, how true is this? Because we all know you don't need forged internals and all that jazz to get to 7k, the ricers do it and some times can't even handle 300 hp, but they can get to 7k.
Would you need a better oil pump? Bigger oil pan?
Just for education here. Thanks!
My two cents. I will not even discuss heads or camshafts. The stock shortblock might live at 7000 RPM for a few short bursts but will eventually fail, sooner rather then latter. The stock rods and pistons will be the first items too fail. The rod bolts will stretch and the big end of the rod will become oval resulting in rod bearing failure or worse. The cast pistons will also eventually fail. It is really not that hard to get a SBC to handle 7000 RPM but at the bare minimum it will take new pistons, rods (Stock rods set-up correctly will work but it is easier and probably cheaper to get some aftermarket rods), and good main bearing bolts (ARP) to keep the 2-bolt bottom end stable.
A stock SBC will take 6000 RPM for a long time with short bursts to that RPM but 7000 RPM is a whole other situation. Going from 6000 RPM to 7000 RPM increases the load on the whole rotating assembly by 36%. (Force increase by the square of the speed change)
One thing not mentioned so far is the need for floating piston pin type pistons. When pressed pin pistons spin 6k+ on a regular basis regardless of L4 or V8 the pins want to "walk" in the rod. A loud exhaust can hide the noise or it's noticed .... "but what is it" ...eventually you know when rod exits block. 7k in the old days was because of the 4.10 + gear ratios we ran, turning 3500 cruising on the highway, 10 mpg or less was acceptable, those days have past I think
I will respectfully disagree, you do not need floating pins to run 7000 RPM. The main advantage of a floating pin is ease of disassembly. There are some minor friction advantages to a floating pin but they are not needed to run 7000 RPM.
I remember reading an article titled, "Siren Song of RPM". It pretty much discouraged people from trying to crank 7K rpm on their engines. The LS7 is touted as having a 7K rpm redline but even it doesn't make its power all the way up there.....and that's 7 liters of push with some great flowing heads and Ti rods from the factory. So super strong, super light bottom end matched with great flow numbers and still not a reason to wind up to 7K rpm. The more I read, the more I see the only engines worth winding up that high are solid rollers.
I'm guilty of lusting after 7K rpm bragging rights with a build but I realize it's amazing how much the game changes in a span of 500-1000 additional rpm to get to 7K. As long as it can rip past 6 to maybe 6300-6400 would make me happy. I've heard of some guys buzzing their hydraulic rollers up to 6700 rpm or so with top shelf parts but it isn't a regular thing and man, that is getting too risky, to me.
You honestly don't make any sense at all. What the hell does a camshaft have to do with the max RPM rating of a spring? I could have the best camshaft in the world, the point is, those springs aren't going to go passed 6800 RPMs without causing valve float.
I think what he is trying to say is that for those springs to get to 6800 rpm's then it would have to have the perfect combination.
AFR probably built an engine, or had one built, that was 100% perfect for those springs for them to handle the 6800 rpm's. As in the perfect camshaft, crank, rods, pistons, and all the other stuff.
I am not saying you are wrong and they are right, or even that I am right cause it is very likely that I could be wrong.
Here's PDC to 7K with an LT1 however, I wouldn't dream of doing in on a stock short block. Especially if you plan on doing it more than once.
That engine is still alive its my daily driver.
So it can be reliably done, but not with a stock SBC and its really not that expensive to do, if you find the right guys. (guys = machinist for bottom end, the head porter/camshaft/valve train specs guy and the tuner).
The oh buy the ways are going to be the budget killer. For example if you are spinning the engine like I do... SFI rated flex plate is a prudent purchase, so is a well balanced rotating assembly.
When I started my mods C4s were the bang for the buck performance vehicle. If I were to do it now I'd start with an early C6 or a later C5 Z06.
Big difference in having a spring that can control mild ramped .500 lift cam at 7000 from the spring trying to handle an aggressive lobed cam with a .700 lift (both lifts are at the valve)
Or as the devil's advocate I'm certain those springs will handle a zero lift cam at 11,000 rpm
The AFR web site states that hydraulic roller cams can experience valve float at 6200-6400 RPM. They recommend upgrading the springs for higher RPMs. So the basic 195 head is not intended for 6800 RPM.
The thing nobody has really mentioned is balancing. A stock rotating assembly is not balanced to the degree you would want for high RPMs.
