I have a set of wheel speed sensor wiring from a 1993 ZR1. Can anyone tell me what or if they will fit any other years?
Thanks,
Rob
If you have the short extensions for the front which are the same each side they will fit '91 through end of production. If you're talking about something other than you need to be more specific.
Thanks for the response. I've attached a photo of the wiring I am referring to. I have the fronts and backs. If you could help me identify them I would appreciate it.
Thanks,
Rob
You have sensors for the rear and you have "extensions" front sensor (hub) to primary harness. I mentioned the extensions will do '91+ already.
The rear sensors are right and left specific, you mention they're from a '93 ZR-1 so they would do the following all C4 from '88 -'94 and '95 ZR-1. They aren't correct for '95 or '96 base cars. One appears to have the tag still attached so the other should identify itself.
