ignition problem - think it's the VATS
Old Jul 14, 2002 | 09:57 PM
mikedh50's Avatar
mikedh50
8th Gear
Default ignition problem - think it's the VATS
Every couple of weeks or about every 30 times I start the car, only the dash lights come on with nothing else happening as if the battery is dead. The battery is always 12+ volts and I've put in a new starter and coil. After waiting about 15 minutes the car will start so I figured it's probably the VATS acting up. Where can I get a VATS bypass kit and how does it install? Should I also replace the key and ignition switch? Thanks. I have a '93 LT1
Old Jul 14, 2002 | 10:58 PM
Mile High
Mile High "91"
Default Re: ignition problem - think it's the VATS (mikedh50)
http://www.madirect.com part #601-114 $59.99
