Putting L98 back together
Old Jul 14, 2002 | 11:47 PM
djbraxton's Avatar
djbraxton
Default Putting L98 back together
Need some help really bad, after about a year, I'm putting my vette back together. On the water pump how many studs are there, I'm confused on hooking up the air pump bracket/pwr steering. Does the air pump bracket attach to the water pump? I'll probably have alot more questions before it's over.
Thanks alot for all your help!!!
Old Jul 14, 2002 | 11:58 PM
scorp508's Avatar
scorp508
There are 2 bolts on the driver's side of the water pump, and 2 extended bolts/studs on the passenger side that the AC bracket also use to attach. The AIR pump on the driver's side has it's own bolts that screw into the cylinder head. :cheers:
