Power steering fluid
Old Feb 22, 2014 | 10:21 AM
rhinoevans's Avatar
rhinoevans
Default Power steering fluid
FSM and owners manual call for synthetic. Can't find it any where, even the chevy dealer says they only carry non synthetic fluid and that is what has been in the new vetts since 2000.
I know royal purple and redline make some. Chevy dealer said today's power steering fluid better than what was available in 1994,
Have a small leak on the return hose on a 1994. Also hose has been discontinued.
Any comments on the fluid to use???
Old Feb 22, 2014 | 10:49 AM
Silver96ce's Avatar
Silver96ce
I ran into the same problem. I purchased a couple of gallons of Valvoline power steering fluid on closeout from one of the parts stores and periodically siphoned out the fluid from the reservoir replacing it with the new fluid. I did over the course of last summer. This year, I am going to start siphoning again and replacing with a couple of 12 oz. bottles of Lucas Power steering fluid with conditioners.
As for the return hose - is this it?
http://www.autopartswarehouse.com/sk...FYEDOgodeQcABw
Old Feb 22, 2014 | 11:08 AM
rhinoevans's Avatar
rhinoevans
No, it is the hose from the reservoir to the Pump. Seems to be a hard plastic and not just a rubber hose. Just found some Royal Purple at NAPA. Guess I could siphon out old in reservoir , add new and repeat a few times.
So you are now running non synthetic Lucas PSF? No issues?
Old Feb 22, 2014 | 11:14 AM
Silver96ce's Avatar
Silver96ce
Currently it is the Valvoline non synthetic. No issues. I use the Lucas in my other vehicles and am going to start replacing with it in the vette this year. No issues with the Lucas in other vehicles.
Old Feb 22, 2014 | 11:23 AM
Silver96ce's Avatar
Silver96ce
I should also add I used the Lucas to help quiet noisy pump on a 2004 Dodge Intrepid and used (one bottle) it in my 1994 F150 after I rebuilt the steering gear box. The F150 uses Ford tranny fluid but I added a bottle of the Lucas just as a safeguard after the rebuild.
Old Feb 22, 2014 | 12:07 PM
c4cruiser's Avatar
c4cruiser
I'm using Red Line PS fluid in my '87. The pump was making some nasty noises after track days so I thought I would try the Red Line fluid. The pump (original) quieted down and works fine. I did add a small fluid cooler which probably helped too. The early non-Z51 cars didn't have coolers.
Flushing the old fluid is fairly simple. Remove the return line and start the engine and let it idle. Slowly turn the steering wheel to the left and right to the full lock position. As the pump pushes the old fluid out, add new fluid to the reservoir. It probably needs to be a two person job to make sure that the old fluid doesn't spill anywhere or overflow a catch container and that the reservoir is kept at the "Full" line.
Once new fluid is coming out, shut the engine down and re-connect the return line. Start the engine again and turn the steering wheel to the let and right a few times. Check the fluid level and top off as needed.
Old Feb 22, 2014 | 06:36 PM
BucfanTitan's Avatar
BucfanTitan
C4cruiser- that is great idea. I always did the turkey baster. Take a little out of the reservoir refill with clean. come back a day later do the same again until it looks clean. but that is a much better idea.
Thanks!!!!
To Power steering fluid
