Passenger window goes up too far
Old Jul 15, 2002 | 01:28 AM
kawboy5792's Avatar
kawboy5792
Default Passenger window goes up too far
hi....can you guys tell me how to fix this: my passenger window goes up to the normal height, then the front of the window hyperextends. if the window is up too high, then the window wont seal to the weatherstrip right and it bangs into the roof. how can i get it to stop at the normal height? :confused:
Old Jul 15, 2002 | 11:44 AM
greg84's Avatar
greg84
Default Re: Passenger window goes up too far (kawboy5792)
hi,take off the door panel and you should have 2 adjustment brackets bolted to your door panel that control how high your window goes.on your glass there also is 2 guides that are bolted on the glass.lots of times the brackets on the glass become loose and throw your aligement off.good luck,greg84
