Is there a way to get digital reading of oil temp. ,coolant temp. ,and volts where the milage is normaly displayed I have looked in manual and have found no reference to this operation. Someone told me that there should
be a button that says guages near the trip monitor switch any ideas??????
:confused: :confused: :confused: :confused: :confused: :confused:
No it was not offered until 1992. I have a 1991 Dash and engine harness in my car and I wanted this as well.. the 1992 CCM controls the digital readouts you want to the Cluster, but the 1991 Cluster and 1992-newer clusters are different. even if you swapped in the 1992 cluster and CCM you would also need the 1992 ECM to get full operation. Currently I have not found a way to take the 1992 ECM and get it to control the 1991 L98 motor. once that is done then you could essentially get the digital readouts.
1992-1996 offered those extra readouts.. the 1990 and 1991 did not
