Did the LT1's use any type of valve guide seals? I believe that the valve guides are made of cast iron. Can positive seals be used or do I need bronze liners? I've had these heads apart for so long I don't remember what they used. The guides bosses are cut for positive seals already. Thanks
They are .530. I have teflon positive seals but I'm hearing some bad things about them compared to Viton. As cheap as they are on the site you listed I will probably just get Viton as I haven't heard anything negative about them. Thanks.
I would recomend you use the Viton seals on a street car. The teflon seals are not that good in some of the high vacuum situations street cars run at when part throttle.
The metal clad Viton seals are the best.... all oems have gone to that style and its all I use these days.
Will
