First baseline dyno run....thoughts?
Old Feb 26, 2014 | 12:32 PM
dchildress's Avatar
dchildress
Default First baseline dyno run....thoughts?
I have a 94 6 speed coupe. I just got back from Cincy Speed where they did 3 baseline pulls before the engine comes out for cam kit, headers, clutch, and some maintenance issues. Pulled 289.70. 290.73, and 290.02 at the wheels. Is that pretty normal? I was thinking closer to 230 to 240 max. Only mods are K & N with open lid, MSD Opti, coil, wires, E3 plugs, Hooker shorties, Magnaflow cats, and Corsa exhaust. 105,000 miles.
Last edited by dchildress; Feb 27, 2014 at 02:01 PM. Reason: Added video doesn't really show anything
Old Feb 26, 2014 | 12:37 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
RWHP or FWHP?
Old Feb 26, 2014 | 12:40 PM
dchildress's Avatar
dchildress
At the wheels. I will edit.
Old Feb 26, 2014 | 12:44 PM
FASTAZU's Avatar
FASTAZU
St. Jude Donor '16
That's a strong LT1, My LT5 only did 326rwhp stock!
Old Feb 26, 2014 | 01:10 PM
eatmydst1234's Avatar
eatmydst1234
That is a very strong LT1. What were the torque numbers? Can you post up a photo of the sumo graph?
Old Feb 26, 2014 | 01:32 PM
dchildress's Avatar
dchildress
I never saw the torque numbers. I only have a picture of the HP once pull was done. I was runing video and just hit the picture button. They are going to email me graph if he can. I might have to run up there and pick it up. Will try to insert YouTube link after my phone up loads it.
Old Feb 26, 2014 | 01:41 PM
rklessdriver's Avatar
rklessdriver
Probally using the STD correction factor instead of the SAE....
My 92 back when it was stock (except for 160F T-stat, cut lid, K&N and Corsa) put down 287RWHP using the STD correction factor on a Dyno Jet.
In that trim my car ran 13.30@108mph on regular street tires.
Will
Old Feb 26, 2014 | 06:51 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I agree...stout numbers. Ever drag track it? If so, what's it trap?
Old Feb 26, 2014 | 07:09 PM
dizwiz24's Avatar
dizwiz24
those are very strong numbers.
most bonestock lt1's dyno around 260ish rwhp on dynojet.
Even though I dislike corsa (dont like how the price went from $895 in 2001 to double that - for an unchanged product), I suspect it is helping you.
There were lots of posts around 2001/2002/2003 showing dyno before and after improvements of 15 to 20 rwhp when going to corsa. I found it hard to believe, but the numbers were there.
The lt1 mufflers are known to be restrictive and corsa's mufflers are pretty good. Neat how they go from mild-to-wild sound at the touch of the gas pedal.
Though I have to question whether its smaller 2.5" pipes (stock lt1's are 2.75") will be the right direction you want to be in for future mods. Who knows, perhaps it will work great.
Old Feb 27, 2014 | 01:47 PM
dchildress's Avatar
dchildress
80 degree night, maybe 40% humidity. MR Drag radials heated in 2nd.
60 foot :1.992
330 foot : 5.557 @ 0.000 mph
1/8 mile : 8.540 @ 83.850 mph
1000 foot : 11.095 @ 0.000 mph
1/4 mile : 13.210 @ 107.540 mph
Old Feb 27, 2014 | 01:51 PM
dchildress's Avatar
dchildress
[B]
I have been thinking hard about going back to stock exhaust. now I have shorties and MF cats with Corsa and it is pretty loud. Going to cam kit, EM coated long tubes with Corsa might be louder than I really am willing to tolerate. I would like to know if the Corsa is really that much better. I can get MagnaFlow wholesale through one of my distributors and have thought about going with an MF cat back or even the axle back.
Old Feb 27, 2014 | 02:28 PM
nitrusmr2's Avatar
nitrusmr2
STD will only be a few off from SAE correction on a Dynojet depending on conditions..in OH in February I don't think the correction factor will make much difference at all. We're probably talking 5 whp, not 20.
Congrats on the strong LT1.
Aaron
Old Feb 27, 2014 | 02:49 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Good numbers. Looks like a strong LT1 all the way around. Dyno may be a little optimistic, but you have a good motor there.
Old Feb 28, 2014 | 01:37 PM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
good base line. My 95 had close to the same numbers (294rwhp) with a couple extra mods.
Old Feb 28, 2014 | 09:56 PM
dizwiz24's Avatar
dizwiz24
[B]
im not sure about magnaflow, but I know American racing header has a great header/x-pipe product out there right now for lt1 corvettes (I have it).
Though they still leave the muffler choice up to you.
The thing that has annoyed me about exhausts is no-one has come up with a 'weight saving' exhaust.
Even corsa, with the 2.5" diameter smaller pipes, still manages to weigh in the same as an lt1 stock exhaust (from what I hear).
Old Feb 28, 2014 | 10:41 PM
l98tpi's Avatar
l98tpi
Max G’s
http://youtu.be/MF7ATb_K994
What kind of cam and headers are you going with? I just did a LT4 hot cam with a new engine after spinning the bearings. I am going to set up appointment with Tracey to have mine tuned in a couple weeks. Good luck with your mods.
Old Mar 1, 2014 | 10:38 PM
93Rubie's Avatar
93Rubie
Congrats on the strong LT1. I only made 246RWHP and 304RWTQ but that is SAE Net Correction and it was on a Mustang dyno which typically reads less than a Dynoject on a hot July day.
To First baseline dyno run....thoughts?
Old Mar 2, 2014 | 09:58 AM
856SPEED's Avatar
856SPEED
Strong numbers, but on a side note,
seems like they aborted the pull a little early......was it a 6,000 RPM pull ?
Old Mar 2, 2014 | 11:21 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
LT1 won't go to 6k. Cuts off at 5850, and I heard it hit the limiter in the vid.
Old Mar 2, 2014 | 11:59 AM
383vett's Avatar
383vett
Nice numbers Tom.
