Hi guys, anyone have any idea about this? Not all the time, but sometimes during heavy acceleration, I will be shifting gears and when I go from 1st to 2nd or 2nd to 3rd, when I release the clutch and hit the throttle again, the car will lose all power and have nothing at all and then all of a sudden, the power all comes back and she has all acceleration again. It's the weirdest thing. It acts like it is starving for air for like 2-3 seconds. Any help would be appreciated! Thanks guys
I had a blazer do this I changed the fuel pump.. took care of the problem.. so I would say fuel pump.. watch and see if the car turns off completely it is a pump I am sure
I will try all of these things and see what happens. I won't be able to let you know until I get her out in the Spring, but thanks so much for the information!!
Really? W/o running a single diagnostic test, you're that sure, huh? Wow.
After confirming that you have enough fuel in the thing, put a fuel pressure gauge on it, tape it to the windshield. When the symptom occurs, what does the gauge read?
