About to start my brake upgrade, is there a tutorial?
It seems that none of my parts came with instructions and I'll be swapping caliper, bracket, rotor.
I have a pin with a c clip in one box, a tube of grease in another, with 0 directions on how it all fits together.
A tutorial would be fabulous if anyone has a link
It's not the one pin that bothers me, it's that one lonely "C" clip
I found it easiest to install the pads into the calipers and get them into the brackets on the workbench. I planned to install the whole "loaded" assembly in one motion but learned they sent me the wrong bracket
I would not put the pads in the caliper and then install on to the brake line. The reason is you might make a mess or drip fluid and get the on the new pads. If you make a mess, the caliper will be much easier to clean. Then install your pads.
When doing a brake job, always work clean. Get the mechanical done, then when all is ready and cleaned up (including your hands), install the pads and rotors.
