Front running lights come on when braking
Old Mar 1, 2014 | 05:53 PM
phavick's Avatar
phavick
4th Gear
Default Front running lights come on when braking
Hi i'm new to the Corvette world i acquired a 1984 C4, it definitely is in need of some TLC. So far so good except i noticed off the batt that when the brakes are applied without the head lamps on the front running/turn signal lights come on and the shifter console light lights up. On any other car i would think that something is shorted or hooked up incorrectly. Can some one way in on this if it is normal or if you think the same i have some wiring issues to deal with as part of my fix up plan
Thanks Pete
All found the problem there was an 1156 bulb in the one of the rear tail lights on to the many other little problems thanks for a lll your help
Old Mar 1, 2014 | 05:58 PM
DUB's Avatar
DUB
There is something wrong...you are correct there.
Try disconnecting your turn signal switch and see what happens after that.
It is going to be a process of elimination.
I can more than for sure guarantee that some "BOZO" has been in this car doing "whatever" and screwed things up.
I would highly advise buying a GM Service manual...and getting very familiar with the wring section(s)...along with having a good volt/ohm meter.
DUB
Old Mar 1, 2014 | 06:08 PM
phavick's Avatar
phavick
4th Gear
DUB
Thanks good thing i'm an electrician by trade I have been looking on line for a repair manual and wiring diagrams i figured there will be some intense evenings looking over the wiring systems
Pete
Old Mar 1, 2014 | 08:10 PM
383vett's Avatar
383vett
Pete
Congratulations from the Corvette world. It sounds like you car could use a good electrician.
Old Mar 2, 2014 | 04:45 AM
Mark8801's Avatar
Mark8801
Unless someone has messed with it, you more than likely just have a bad brake light bulb.
The brake light bulbs are duel element. One element for the brake light and one for the marker light for each lens. The element for the brake light will break and touch the element for the marker light. When the brake lights are on it will power the marker light circuit through that broken element touching the other element. And wala! Marker lights come on when you hit the brake.
Check the lights real good and look for one that looks odd. Pull the bulbs and see if you can find the one with the broken element or just replace the 4.
Good luck
Old Mar 3, 2014 | 07:47 PM
phavick's Avatar
phavick
4th Gear
Good luck
Thanks we took out all the bulls and changed them we found an 1156 where 2057 goes and that fixed the problem all is good on to the next problem
Old Mar 3, 2014 | 09:57 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Check your GROUNDS!
Old Mar 3, 2014 | 11:14 PM
Drew95's Avatar
Drew95
And don't slam the doors, right coach?
Old Mar 4, 2014 | 06:36 AM
Hot Rod Roy's Avatar
Hot Rod Roy
Jr. Rifle Coach is right. You had a bad ground in the light bulb socket. When you changed the bulb, you inadvertently fixed the bad ground. Either of those two bulbs will work just fine as tail/brake lights! I really doubt you had a bad light bulb. Did you check them?
Here's why you saw what you did with the front lights: When you step on the brakes, current should flow thru the brake/turn fillament to ground. With a bad ground connection, the current thru the b/t fillament went to the tail fillament in that same light bulb, and since all the tail fillaments and the front parking fillaments are connected together, they ALL lighted up!
I like to put a little white grease on my light bulb bases to prevent this problem.
Old Mar 5, 2014 | 07:15 PM
JrRifleCoach
Like Roy explained. The best solution is to go throughout the lighting system. Clean each socket and lube with dielectric grease. Then check and confirm each ground connection is clean and tight. Yes it will take some time to finish a project like this, but you'll only have to do it once.
Old Mar 6, 2014 | 09:29 AM
9T3VETTE's Avatar
9T3VETTE
My experience on this was with a different car (97 VW) but similar issue. When stepping on the brakes, turn signals would go on, when turn signals were on brake light would go on, etc.
Ended up being a corrosion issue in the brake light bulb socket. Cleaned it all up and everything went back to normal.
Old Mar 6, 2014 | 02:09 PM
69mako's Avatar
69mako
Check your bulbs, sockets then grounds. Its an easy fix you just have to locate the bad actor.
Old Mar 6, 2014 | 11:13 PM
Chuck Tribolet's Avatar
Chuck Tribolet
Good explanation, but I wouldn't use white grease. White grease has lithium in it. Lithium is metal and the grease may be slightly conductive. You want a real dielectric grease. I've seen it in the auto parts stores lately.
To Front running lights come on when braking
