Cam Definition
Old Jul 15, 2002 | 05:36 PM
UB2 SLOW's Avatar
UB2 SLOW
From: I could tell but then I would have to kill you
Default Cam Definition
Okay like I said before I am new at this. I got a Cam from a buddy. The Cam is still in the box, never installed. He decided to put an LS1 into his Vette. It reads: Hydraulic roller (LT4 Hot Cam), I:218, E:228, 1.6 Rocker, I:525, E:525, 112 degrees. Can someone define this for me and tell me if this is good? I also got some heads from him that state:Aluminum, intake 195, chamber 54.4, Valve diameter, I:2.00", E: 1.55", angled. These are also in the box and have never been installed. :confused:
Old Jul 15, 2002 | 05:43 PM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Default Re: Cam Definition (UB2 SLOW)
Well the cam sounds like an LT4 Hotcam, which is a very good cam. To use it, however, you need to upgrade your springs, and rockers. I would also highly recommend upgrading your timing chain with this cam.
-Mark
Old Jul 15, 2002 | 06:49 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Sounds like the heads are LT4 heads and the cam is the Hotcam. Looks like it is the complete LT4 top end upgrade that sells for about $2000, minus the intake.
Old Jul 15, 2002 | 07:10 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Default Re: Cam Definition (Vette92)
Stock LT1 heads are 1.90's on the intakes. Pretty sure stock LT4's are 2.0, they usually go 2.02 aftermarket on the LT4's and 2.0/1.56 on the LT1's are as big as you can go on the stock seats. The chamber size is right on with LT4 heads too as the LT1's are 56-58cc's.
Chris
To Cam Definition
