What does this mean
Old Jul 15, 2002 | 09:39 PM
YellowC4's Avatar
YellowC4
Default What does this mean
I was changing headers on the weekend and i loooked on the driveshaft and it had some type of fliud or oil on it does any body know what I should check
Thanks :flag
Old Jul 15, 2002 | 09:50 PM
ittlfly's Avatar
ittlfly
Default Re: What does this mean (YellowC4)
Was it transmission fluid? Which end of the driveline? Rear end? Was it just on the driveline? Any on the bottom of the transmission pan? Need a little more information ........
[Modified by ittlfly, 5:51 PM 7/15/2002]
Old Jul 15, 2002 | 10:05 PM
YellowC4's Avatar
YellowC4
Default Re: What does this mean (ittlfly)
Oh sorry its the front end and it had oil on the dirve line only I put my hands around the transmission and it was dry
Old Jul 17, 2002 | 01:09 AM
YellowC4's Avatar
YellowC4
ab
Old Jul 17, 2002 | 10:33 AM
ittlfly's Avatar
ittlfly
If it isn't blowing back from the engine, then the only thing that comes to mind in that area is the rear transmission seal. Did you smell the fluid? If it has a burnt smell, it's probably trans. fluid. Any tail tale drips on the garage floor? Also, there is a speed sensor in that area on the box that it may be coming from. Just a couple of thoughts....Oh yea..if the u-joint has zerts on it, sometimes the grease gets hot enough to liquidify and run out. Usually in hot weather and sitting around in a hot garage.....
Old Jul 17, 2002 | 11:52 AM
yoslambo1@cs.com's Avatar
yoslambo1@cs.com
it could be the seal where the drive shaft goes in. :confused:
Old Jul 18, 2002 | 11:15 AM
ittlfly's Avatar
ittlfly
Default Re: What does this mean (yoslambo1@cs.com)
Absolutey....but there is usually a tell -tail drip on the tail shaft @ drive line after the car has been sitting a while..... which indicates a bad rear trans. seal. If it is, it is not a hard job to fix.
To What does this mean
