Fuel pressure question
Old Mar 8, 2014 | 09:15 AM
mxw128's Avatar
mxw128
Default Fuel pressure question
I'm running a set of Bosh III injectors from FIC in my 94 LT1. I replaced my FPR a little while ago and I get fuel pressure numbers that are in spec but seem a little low, 40 psi Key on engine off, ~34 running and 43 without vacuum. What psi do these injectors like to run at? Does 34 seem low at idle?
Old Mar 8, 2014 | 09:38 AM
bjankuski's Avatar
bjankuski
That is right where it should be.
Old Mar 8, 2014 | 11:06 AM
MrWillys's Avatar
MrWillys
If you have a scanner you can check your BLM, or long term fuel counts and adjust pressure as required based on results.
To Fuel pressure question
