i know its 6am here in Florida but going to change fuel filter and fpr too this morning on my 1996. i pulled the fuel pump fuse and car wont run at all. so i then replaced the fuse started the car, pulled fuse waited till car died and took only a few seconds to stall out. seemed fast to me, before i pull the fuel filter off and have a ton of gas all over me, should the fuel line be empty that fast, and i connected fuel pressure gage to fuel rail and have 0 psi, so this means good to go, rather be safe then crispy critter lol. thanks for any help before i go for it ...
All you have done is relieve the pressure in the line ; it is still full of gas and it will continue to siphon out from the tank fast
because it is higher than the filter unless you;
raise the front of the car high
or disconnect the supply line at the tank so you only loose what fuel is in the line from tank to filter
Is best to change the filter with minimal fuel in the tank
i plan on jacking it up on jack stands as high as it will go, should this be high enough, i don't think i could ever get the fuel filter higher than the tank.
must be a way because jacking the front of the car up doesn't happen if it's on a lift in the shop
Depends on the type of lift. If it's a two post hydraulic, just move the rear arms out. Of course you can only lift the front so far. But this will make gravity take the fuel in the line towards the tank and away from the filter.
Either way, there's still going to be a fair amount of fuel released when the line is opened up. No way around that really, unless you literally pump all the gas out of the tank and the lines.
Just work fast....That's what I do.......I release the pressure on the schrader valve, wrap a towel around the filter while I unscrew the connections, a little gas won't hurt you....Well , unless you smoke while changing the filter.........WW
I changed the FPR in my '96 last year, and didn't have any issues.
I released the pressure with schrader valve and used a plastic cap from a small spray can, as a "catch can" for what little fuel came out.
With that cap and some paper towels stuffed around, there wasn't any fuel spilled.
Haven't done the fuel filter yet though, but I believe as mentioned the fuel will continue to siphon out if left open.
When I was pulling my 350 engine out to install my 383 using a friends shop, we left the fuel lines at the engine disconnected overnight with the intent of finishing up the engine pull in the morning...When my buddy went into the shop the next morning he found about 15 gallons of gas in the pit under the Corvette.......Lesson Learned, never leave the fuel lines on a Corvette disconnected without blocking them off..........WW
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
You can also peel back the rubber fuel bib from around the gas filler and use a small set of vise grips to clamp off the rubber fuel line. This will keep the gasoline from siphoning out.
Be sure to disconnect the battery when working on the fuel filter as you are working fairly close to the starter and it is easy to create a spark.
Just remove the filter and replace the inlet side first. Tons of gas won't spill out, (because the front is higher than the rear). I've done it with a full tank gas.
kool i have about a 1/4 tank now, on the way to work i was going about 40 and hit the pedal to wot, motor fell on its azz, and with fuel pressure gage hooked up and taped to the windsheild pressure dropped to about 10 psi. lifted my foot and motor took off again. going to install the fuel filter and a/c delco fpr, and see what happens, hope it works. if not guessing the fuel pump must be next i guess..
^^^ That might be fuel starvation from the tank. Fill past 1/2 tank and try the same test.
i get the same thing from the Eng even with full tank of gas.. i think when all is done will most likely have to change the fuel pump too. lol just three more things replaced ....
Decades ago when I first changed the fuel filter on my C4, I did the quicky fuel filter change without disconnecting or pinching the line at the tank. I didn't have much experience then and obviously wasn't thinking ahead. I was using an old trouble light at the time with a naked 100 watt bulb. Gas was running down my arm. I looked over and saw the bulb smoking as some of the gas was cooking on the bulb. I figured I used one of my 9 lives that night. Just be careful and think ahead.
that has to be the best write up on filter change i have seen. and great help also, cant belive it was that dirty in side, i have about the same on mine too, will do the same and post pics of how dirty mine is may also help people on here with when to change thiers...
thanks...
pastamike..
I have been seeing a lot of moisture in my fuel filter in the past couple of years. I guess due to 10 percent ethanol in gasoline these days. I change the fuel filter yearly now.
