Converting Distributor to Vacuum Advance?
Old Mar 9, 2014 | 07:32 PM
DanielRicany's Avatar
DanielRicany
Default Converting Distributor to Vacuum Advance?
Hey guys, I wanted to upgrade my ignition system to go with my Miniram and AFR set up.
I plan on purchasing the MSD 6AL2 ignition box along with a D.U.I. Vacuum Advance HEI distributor. The distributor part number is 12720.
What would I need to make this change? Would I have to make any modifications to the wires to get the tach to work or anything?
Is it possible to remove the EST in the tune?
The car is a 1985 with an 870 ECU.
Thanks!
Old Mar 9, 2014 | 07:37 PM
cohocarl's Avatar
cohocarl
Thanks!
I don't think you'd have any problem w/ the 6AL2, but by going with a different dizzy, you'd lose the computer's ability to advance or retard the timing. It would then advance due to the weights & vac. in the D.U.I. instead. (I THINK....BUT I COULD BE WRONG).
Old Mar 9, 2014 | 08:00 PM
DanielRicany
That's what I want
Old Mar 9, 2014 | 08:08 PM
cohocarl's Avatar
cohocarl
That's what I want
Well, f.w.i.w., last summer, I converted my '85 from T.P.I. over to a carb. I put on a standard vac advance M.S.D. hei distributor. Everything seems to be fine. No, I don't have any computer control on the engine, i.e. knock sensor retarding the spark, etc.
Old Mar 9, 2014 | 08:30 PM
dragracer111's Avatar
dragracer111
You will have to make sure the stock computer still receives a tachometer signal to keep your air and cruse working. You will also have to tie the 6al tach wire to the tach filter to keep you stock tach working. I just installed the 6al programmable in my 90 and found out the hard way you need a full 12+ switched volts or it will not turn it self on. I had 12.4 at the source and only 11.5 at the box. Bad wire.
Old Mar 9, 2014 | 08:35 PM
frankinvett84's Avatar
frankinvett84
Not trying to hijack, BUT cohocarl can you elaborate on your carb conversion? How does IT run? is it just as dependable did you do the torque conveter lock up switch "thing"?
Sorry I'm just trying to get as much info as I can, Thanks
Old Mar 9, 2014 | 08:49 PM
vetteoz's Avatar
vetteoz
That's what I want
So you are going to have to reprogram the ECM for fuel control only
Old Mar 9, 2014 | 08:53 PM
vetteoz's Avatar
vetteoz
Originally Posted by dragracer111
You will have to make sure the stock computer still receives a tachometer signal to keep your air and cruse working. .
ECM doesn't get a tacho signal.
It receives it's RPM info from the dist reference pulse on the Ppl / Wht wire of the 4 wire connector at the dist base
( which the OP loses with a non CC vac advance dist )
Old Mar 9, 2014 | 09:17 PM
DanielRicany
What can I do to allow the ECM to get an RPM signal?
Old Mar 9, 2014 | 09:24 PM
cohocarl's Avatar
cohocarl
pm sent
Old Mar 9, 2014 | 09:39 PM
dragracer111
/8a-20-5.jpg[/IMG]
Vetteoz you helped me get mine wired correctly I tied the msd tach wire directly to the ecm (the purple white I believe) and every thing works fine now. Thanks Again.......................Jim S.
Old Mar 9, 2014 | 11:06 PM
BOOT77's Avatar
BOOT77
Are you using the 6al2 programmable?
Old Mar 10, 2014 | 11:14 AM
DanielRicany
No. But I realized that I need a Distributor Reference Pulse in order for the computer the fire the injectors. So if I want to use this distributor, I'll have to buy a crank trigger, and most of them are around $250.
Does anybody know of a cheap one? Maybe around $100?
Old Mar 10, 2014 | 01:06 PM
c4cruiser's Avatar
c4cruiser
You may find that the non-computer HEI distributor will not fit when you install it. The vacuum advance canister may very well interfere with other components attached to the intake manifold.
I have read that the early HEI distributor housings are larger in diameter than the 85-later OEM Corvette C4 distributors. Could be that that alone will cause a problem.
Check with D.U.I. before you order.
Old Mar 10, 2014 | 01:57 PM
five7kid's Avatar
five7kid
I'm trying to imagine the benefits of this conversion, and I'm coming up completely blank.
Old Mar 10, 2014 | 02:01 PM
DanielRicany
The benefit is that I won't have to tune the timing tables. They take too long and are a hit or miss. I have to guess what load variable is at which RPM, and I have no knock count data, it relies all on ear. This just makes it a lot easier.
Old Mar 10, 2014 | 03:53 PM
BOOT77's Avatar
BOOT77
85 & 86 are larger cap distributors, in 87 they switched to the small cap. Not sure if you could clock the dist body with enough room for HEI vac advance can. I'd have too look at my car and see what's all around it, but you can buy a msd small cap vac dist if room was the problem. 87 up at least can use this for their msd box http://www.summitracing.com/parts/msd-8876/applications
To Converting Distributor to Vacuum Advance?
Old Mar 10, 2014 | 04:04 PM
five7kid's Avatar
five7kid
It makes more sense to me to convert to an EFI system that is easier to tune and gives better feedback. But, that's just me, I guess.
Old Mar 10, 2014 | 10:24 PM
cumbercr's Avatar
cumbercr
It would be easier and cheaper to upgrade the ECM so you don't have to guess.
Old Mar 11, 2014 | 07:33 AM
ex-x-fire's Avatar
ex-x-fire
Try this, put the original ignition control module in the vacuum advance distributor. Then unhook the timing connector. That should eliminate the est to drive it.
