Converting Distributor to Vacuum Advance?
Old Mar 12, 2014 | 10:55 AM
beerme's Avatar
beerme
Originally Posted by BOOT77
85 & 86 are larger cap distributors, in 87 they switched to the small cap. Not sure if you could clock the dist body with enough room for HEI vac advance can. I'd have too look at my car and see what's all around it, but you can buy a msd small cap vac dist if room was the problem. 87 up at least can use this for their msd box http://www.summitracing.com/parts/msd-8876/applications
Uh 87 what??? My 87 has the large HEI not the small, and it was factory until I replaced with a new/rebuilt factory one anyway.
Old Mar 12, 2014 | 02:48 PM
BOOT77's Avatar
BOOT77
I could be mistaken, but I thought it was 87 with the roller cams. From my research back when I had my thirdgen and even a quick check multiple resources say 87, If you check my part link it says 87. Still like my 86 is later and has the alum heads, distributor size could have been a split for 87 or if you are not the orig owner it could have been replaced.
edit: Just read all C4 had the large cap, if so that's interesting.
Old Mar 12, 2014 | 03:58 PM
383vett's Avatar
383vett
Originally Posted by DanielRicany
The benefit is that I won't have to tune the timing tables. They take too long and are a hit or miss. I have to guess what load variable is at which RPM, and I have no knock count data, it relies all on ear. This just makes it a lot easier.
timing tables are pretty much the easiest part of tuning. Set the timing for 22 degrees at idle. Have it come all in at full throttle, 33 degrees at 3000 rpm is a good place to start. at part throttle (cruise conditions), you can dial in up to 45 degrees. There, you're all done!
Old Mar 13, 2014 | 01:23 PM
bjankuski's Avatar
bjankuski
Copy a traditional SBC advance curve and dump that into the timing table and it will work fine. It will act just like the mechanical advance distributer with vacuum canister that you are trying to create.
