TCC lock-up
Old Jul 16, 2002 | 01:15 AM
Racer1x's Avatar
Racer1x
Default TCC lock-up
My problem is with the tcc lock up.The converter will intermitently unlock on the freeway.I have a scanner (otc) but have no codes and dont see anything out of the ordinary.When I was in data-stream i did notice that when it would unlock the egr would go from 25% to 100%.I know the ecm is sending a signal for it to unlock, from scanner but do not know whats sending a signal to the ecm.
I have a switch jumpering it on top outside terminals and it stay engaged all the time.
Any help will be appreciated.
Old Jul 16, 2002 | 02:54 PM
Racer1x's Avatar
Racer1x
Default Re: TCC lock-up (Racer1x)
Come on guys i'm going crazy trying to fix this.
:smash: :mad
ANYONE
Old Jul 16, 2002 | 03:06 PM
Vic'89's Avatar
Vic'89
What year car is it ?
Vic
Old Jul 16, 2002 | 06:09 PM
Racer1x's Avatar
Racer1x
Default Re: TCC lock-up (Vic'89)
1993 stock
Old Jul 16, 2002 | 06:31 PM
JS's Avatar
JS
1st place to start is the brake pedal switch. Does the cruise work OK if it drops out they are related.
My manual says push the switch in then pull up on the brake pedal and it will push the switch back up to the correct position.
JS
Old Jul 16, 2002 | 09:40 PM
Racer1x's Avatar
Racer1x
Default Re: TCC lock-up (JS)
Ya, on the scanner it shows when you hit the brake and it does not show that it is when it unlocks intermitantly.cruise works fine.so I ruled out the tps, brake light switch.
Old Jul 17, 2002 | 02:53 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Connect a test light (mini LED in series with 2.2kOhm resistor works well) across ALDL pins A & F.
When the light goes out the ECM has sent the TCC lockup signal; so you can more easily monitor the signal instentaneously.
Old Jul 17, 2002 | 03:17 AM
Racer1x's Avatar
Racer1x
Default Re: TCC lock-up (65Z01)
THE SCANNER I have shows when the tcc locks and unlocks.I have a switch on the aldl a&f and it stays locked when I switch it on.
I'm trying to find out why the ecm is sending a signal to unlock it.
I know I have a cracked exhaust manifold but I dont know if that would affect it.
Old Jul 17, 2002 | 11:51 AM
65Z01's Avatar
65Z01
That "test light" across the ALDL terminals with your sw Off will show exactly when the ECM is sending the command to the TC clutch.
Old Jul 17, 2002 | 01:22 PM
Mo_Bandy's Avatar
Mo_Bandy
Racer,
Something you may want to check... and this is totally perhaps out there... the ecm will disconnect the TCC if it sees a misfire... are you having any probs with your optispark? what maybe happenng is that it is occasionally misfiring and unlocking the tcc.
you may want to scan the cylinders for misfire events... just thought
Mo
Old Jul 17, 2002 | 02:13 PM
Racer1x's Avatar
Racer1x
Default Re: TCC lock-up (Mo_Bandy)
When I have the aldl jumpered and the tcc is locked, I do notice that the rpm jumps a little up and down maybe 200 rpm.Does this sound like a opti going out? I cant really feel a huge misfire but maybe a slight one.
Old Jul 18, 2002 | 03:04 AM
Racer1x's Avatar
Racer1x
My scanner does'nt show cylinder misfires so I might have to take this one to the shop :cry . I'm going to keep this thread alive for a little while to see if someone has some insight.
Old Jul 18, 2002 | 04:25 AM
Mo_Bandy's Avatar
Mo_Bandy
Racer,
I just recalled something.. ~shutters~ I had the very same thing happen on my ford explorer... id cruise and it would rev on and off about 200 rpms.. i took it to AAMCO ... they did a diagnostics and it was the TPS, I know you ruled it out but the throttle response wasnt not irratic or anything.. i was shocked that they found that as being the problem but it did fix it...
Just a thought...
Mo
To TCC lock-up
