It could be the diverter flapper. Can you hear it change when moving the control? If not you probably don't have vacuum. the valve is located on the lower passenger foot rest. My '85 doesn't have the plastic so I can get to it. The line is yellow. First check your vacuum lines on the engine.
Ok I replaced check valve.
Did not fix the problem.
Vacuum line going to motor is good. Line going to cruse ect is good.
My question is the vacuum line that goes down. it is plastic. I going to guess that is has a crack or broke off. Question is where does it go?
I see it going down but that's it.
Would it run in a wire loom?
It goes into the wire loom and into the cabin through the bulkhead feedthrough behind the passenger side head. It attaches to the rear of the HVAC control head.
This pic from Agent 86 shows the vacuum line very well (behind the pink distributor power wire):
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
did you check the lines in back of the control? Mice feast on them
Best I can tell the vacuum lines at the hvac unit in dash are in god shape.
I see 2 vacuum line coming off unit. Black and yellow.
I took the passenger under dash apart and I see where the yellow line goes. Looks good.
When I stick my hand why up in the dash. Which is a tight fit. It feels like the lines has a T in it and some type of connector. Not real sure because I can not see it.
What you're feeling could be this junction part. It joins the vacuum lines from the engine compartment (on the right) to the vacuum lines inside the cabin. The black vacuum line is the vacuum source from the engine. The white vacuum line is for the heater water control valve (which was eliminated around 1988 -- I'm not sure exactly when that happened). The bottom looks like it should plug in somewhere but in my case it was just floating around inside the instrument panel:
Running a new vacuum line into the cabin might be a little difficult. It goes through this guy (bulkhead feed through):
It's basically a plastic box filled with some kind of sealer. The sealer is about 1" thick. That little white "thread" in the center is what was left of my vacuum line after it got melted in a fire.
thanks for the pictures.
I am hoping the problem is a line in the engine compartment.
Does the feed line run from the check valve directly to the bulk head or does it route around the passenger side of the car?
I ran a temporary vacuum line from the check valve into the cab and to the back of the hvac unit. Still no change, Took off the white round plug with several vacuum lines in it. I di not have any vacuum on the back side of it?
Can that part be bad?
My deed line has very good vacuum. I do not here any leaks.
Had the same problem in our 84; after much wasted time of searching for the problem it turned out to be a broken vacuum line. I was in the shop working on it when a neighbor walked in blowing his cigar smoke in my face, he thinks its funny. ya ha ha. but then it hit me,i pulled the vacuum line off the motor and had him blow his smoke into the line. low and behold after several blows smoke was seen coming out down by the starter. opened up the harness and found the vac.line broke in half. on ours that was the routing on its way to and from the heater control valve. repaired broken line problem solved. not saying that's your problem,but if you can blow smoke through it you may find a or if theres a break. just my 2 cents
Ok I think I got it. Have to run a new vacuum line. I think the hvac selector valve was pluged.
Anyway got it working. Thanks guys
My next problem is my cable switching from hot to cold. It is kinda stiff but the black outer part of the cable need to be held in place. When holding it by hand it works great.
