Managing lateral weight transfer
Old Mar 11, 2014 | 01:55 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default Managing lateral weight transfer
I think we all have weight transfer for braking and acceleration figured out.
Transfer weight to the front and the brakes grip a lot better, which is why you squeeze the breaks.
Same for the gas, squeeze until you start transferring the weight, and you get more grip.
But what about lateral?
Are you guys trying to maximize it or minimize it?
How about quick transitions where you're bouncing back and forth, like a slalom?
How are you including tire slip angle into the mix?
Old Mar 11, 2014 | 07:15 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I'm not sure what you're asking...but I try to apply the "load" as smoothly/progressively as possible, so as not to upset or overwhelm the lateral traction.
Old Mar 12, 2014 | 11:49 AM
BrianCunningham
Getting some good advice here
https://www.corvetteforum.com/autocr...post1586380327
Old Mar 13, 2014 | 04:25 PM
BrianCunningham
I've read all the books
Looking for different perspectives
I know FWD cars go faster with 3 wheels on the ground.
Most RWD & AWD cars try to keep all 4 on the ground.
Though BMW's go faster pulling the inside FRONT tire off the ground.
Old Mar 13, 2014 | 04:44 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I don't think "a car goes faster by lifting a tire". I think there are particular cars, the due to engineering short falls lift a tire when they are performing at their peak. The tire lift is a by - product of a shortcoming...not a contributor to performance.
The BEST performance is to have all 4 tires square to the ground, with equal weight on all 4 tires. Of course the CG being above the ground makes that scenario impossible, but that would be the goal.
Old Mar 14, 2014 | 12:48 PM
Deakins's Avatar
Deakins
I would agree, you want to maintain your contact patch as much as possible. The race cars that lift the tire off the ground are generally suffering from limitations in the chassis and suspension design. You will never see a F1 car with a wheel off the ground unless things have gone pear shaped on them....just my .02
To Managing lateral weight transfer
