i need help
Old Mar 10, 2014 | 06:30 PM
taurus1970's Avatar
taurus1970
4th Gear
Default i need help
I have a 85 corvette it starts but does not run I have done everything I can think of changed the distributor the cap wires rotor and mass air flow new prong tps iaic cleaned fuse box changed all fuses and new alternator thermostat cleaned throttle body fuel pump and it's relay knock sensor fuel filter still no run not sure where to go now thank you for your time John
Old Mar 10, 2014 | 07:01 PM
don hall's Avatar
don hall
http://tech.corvettecentral.com/2011...trouble-codes/
Old Mar 10, 2014 | 07:19 PM
summerst's Avatar
summerst
Have you checked the ohm readings on each injector?
If there is any reading below 12 ohms, the injector is no good.
Old Mar 10, 2014 | 07:24 PM
joe paco's Avatar
joe paco
probably everything you have done was a waste of time. the first thing you have to do is troubleshooting.
starts and runs how long? do you have a strong blue spark during cranking?
was it timed with the new distributor? with front balancer at TDC for #1, which direction is the rotor pointing, assuming the distributor is a clock face lying flat with the 12 facing the rear of the car? are you sure the wires are installed in correct order?
do you have fuel pressure at the rails? have you checked the injectors for ohms? have you checked for injectors firing -the blinking light test?
even before that, do you have a factory service manual?
Old Mar 10, 2014 | 07:25 PM
taurus1970's Avatar
taurus1970
4th Gear
Default reply
I did check for codes I get 12 witch means nothing at this moment I did not check the injectors I will look at that 12 ohms in the am thank you very much
Old Mar 10, 2014 | 07:33 PM
taurus1970's Avatar
taurus1970
4th Gear
I do have have spark and yes the distributor was installed right and was timed in with a light when it disides to run the other things I replaced needed to.be replaced like the altanater and the thermostat. It's a weird deal it run when it feels like and shuts down when it want a couple tow calls to bring it back home
Old Mar 10, 2014 | 07:47 PM
joe paco's Avatar
joe paco
the definition of the problem is better, John. you realize that we the reader have no idea of what anyone's expertise is.
so, it runs ok, but shuts itself down. was the coil replaced, and ignition module? if you are prepared, you should have a means of checking for spark when it shuts down.
does it stop suddenly, or shudder and cough? misses? stops at idle, or while under power? the more descriptive you can be the more likely you are to fix it. have you checked a couple plugs for fouling?
ohm the injectors as he suggested, although intermittents are not usually a bad injector.' code 12 is not a concern.
Old Mar 10, 2014 | 08:16 PM
taurus1970's Avatar
taurus1970
4th Gear
Coil was replaced with accel super coil. I may add I put it I the shop and they thought it was a vac leak and when he was looking for the so call leak he set the car on fire yeah real fun time with this car alright back to the story at hand i feel I.have a flood car the engine has been replaced and someone has been into the wiring I been removing butt connectors in the engine harness so I have been soldering them back. In mass air flow and air pump and ground also few other things the iaic makes a funny noise clicking I have not yet been on.that side of the harness besides disconnecting the a.c. and replacing iaic and tps. Thank god it was a free car or so call job Bonus thank you
Old Mar 10, 2014 | 08:33 PM
hooked073's Avatar
hooked073
what is your fuel pump and pressure doing?
Old Mar 11, 2014 | 04:03 AM
Cliff Harris's Avatar
Cliff Harris
IAC clicking: are pins A & B of the ALDL connector shorted together? That's the only thing I know of that will cause that.
Old Mar 11, 2014 | 05:14 AM
Joe C's Avatar
Joe C
start with the basics. spark, fuel, timing. did you run a fuel pressure test?
To i need help
