Question for the mechanics
to think about dropping in a new engine that offers about 300 hp? And if not, where would you suggest I look for one? And what kind of engine would I look for? I've looked at places like The Engine Factory but I don't really know where to start? Or would something like an Edelbrock package work better? Really confused. Could really use some serious advice. I want to get this right. Thanks.
Parts and mods are better for a budget, but a complete engine swap is quicker.
I'll let someone else point out all the parts/mods that can get you too 300hp.
http://forums.corvetteforum.com/memb...421-vette.html
I even got to spend a little time in the Port Aransas jail (I was innocent!) during a Spring break incident.
http://forums.corvetteforum.com/southwest-44/
Fresh stock motor. Open the intake base to match the heads and siamesed runners.
A good cam and headers. Add a dyno tune. Find some 3:07 gears.
Enough power to make you smile, the right sound to remind you its a Corvette.
Or you can buy mine...
I have never heard anyone in jail claim they were guilty......
.....WW
look at various crate engines, I'm sure someone here has specific suggestions, but look for:
a little more compression; a little more cam, a few more cubes ? better heads and of course the bottom line, more horsepower / more torque.
http://www.enginefactory.com/images/375hp_6_03.jpg
* 4 Bolt Main, Full Round Seal Block
* 350 Chevy Crankshaft
* PM connecting rods
* H345CP Hypereutectic Pistons
* Sealed Power Chrome Moly Rings
* Elgin Double Roller Timing Set
* Edelbrock Cylinder Heads #60879 60cc
* Comp Cams Hydraulic Roller Camshaft
Duration @ 050, 206/210, Lift 450/480, 112 Lobe Sep.
* Comp Cams Hydraulic Roller Lifters
* Federal Mogul Tri-Metal Bearings
* New pushrods
* Comp Cams Roller Rockers
Melling High Volume Oil pump
* Complete Fel-pro Gasket set
* New Harmonic Balancer
* New Flexplate for Automatic Trans.
(Standard Flywheel add $200)
* New Chrome Oil pan, Timing cover and Baffled Valve Covers
* New Water Pump
* Oil Filter, Dipstick and Diptube
* Packaged and Crated for Shipment
* Sold Outright no Core exchange
$4,900.00
Good luck with it!!
