Howdy. I have a 94 that the service engine light comes on. It happens intermittingly but my vet still drives and runs good. When I stop and it sits for awhile it may take 3-4 cranks, then starts and runs good. I was told that the opti spark distributor is bad and needs replacing?? When I look at theold paperwork from the previous owner it was changed at 148k. Now has 163K. Is this the characteristic of a bad opti spark?? Thanks, Tom
Reason: Thanks to the folks here, I resolved the problem
Welcome, First thing is check it for codes. Most auto parts stores will do for free if you have no way. You can do it with a paper clip. post up in the C4 section, and do a search on opti-spark. also check the tech tips. You came to the right place for advice lots of very knowledgeable members here willing to share.
Howdy. I have a 94 that the service engine light comes on. It happens intermittingly but my vet still drives and runs good. When I stop and it sits for awhile it may take 3-4 cranks, then starts and runs good. I was told that the opti spark distributor is bad and needs replacing?? When I look at the old paperwork from the previous owner it was changed at 148k. Now has 163K. Is this the characteristic of a bad opti spark?? Thanks, Tom
With the description you list (engine running good) and only 15k miles on the current Opti, it does not seem like the Opti is "bad".
The check engine light is telling you a "code" has been set.
Find out what code that is before guessing at what might be wrong.
Originally Posted by kimmer
Could be a number of things but the opti, I doubt it
Given the description of "runs good", the Opti seems to be pretty low on the list of possibilities.
Boy, I just can't get over how every time one of these things has the the slightest hiccup, someone points to the opti. Usually the mechanic that knows he's gonna charge $2,000 to replace it.
I agree completely with the two above. Start with the basics, plugs, wires. Check the fuel pressure regulator as well, these don't last forever. Also, how old is the battery? A weak battery can do this as well. If by 3-4 cranks, you mean rotations, that's not horrendous. It's probably something pretty minor and fairly simple.
Thank you. If I'm not mistaken distributors don't take their time going out, they just do. Is this correct? Had two shops tell me the same thing, that the opti spark needs replacing by the code that came up. I wasn't there so not sure. Being I just bought the vette, not sure the last time either it was tuned up or the fuel regulator switch was replaced. I think that is definitely the first steps I will take. Really appreciate this info from you and everyone. will let you know the results. Again, thanks and have a great day. Also the battery is fairly new and the volt gauge reads close to 18.
Not true..... optis destroyed by corrosion may take a year (+-) after moisture intrusion..... some failures can occur immediately
It shouldn't, but I'm not smart enough to rule out high voltage
causing opti problems.
Well, that make two of us. Thanks. By the way I cannot find the voltage regulator on my 94. By chance is it in the alternator like the older C4's. anyone??
Every once in a while the battery charging light comes on. Since the battery is fairly new and it was suggested the voltage regulator may be bad due to the 18+ charging, is it in the alternator like the older C4's, I cannot find it.
