stumbles under load at speed
Do you have the info on the prior maintenance from the prior owner?
Because it could be a maintenance issue or other problem.
So with that in mind -
1. How many miles on the car.
2. How old are the spark plugs, spark plug wires, fuel filter, vacuum lines. Do any required maintenance before going any further with the diagnosis. Clean the throttle body and IAC (idle air control) valve attached to the throttle body.
3. Were there any problems with the car before you bought it that were supposedly fixed.
4. Have you checked the fuel pressure on startup, at idle and checked leakdown after shutting off engine.
5. Have you pulled any spark plugs to check their condition - wet, sooty, tan and checked their gap setting.
6. Have you checked for codes? Go to post #18 of the following thread - http://forums.corvetteforum.com/c4-g...ps-w-pics.html
If so, what has come up.
Start with these and see what you come up with.
People tend to tip toe around these days before they say opti. Many other troubleshooting steps have already been indicated which is correct to do. Not that many symptoms stated in the initial post but my thinking was that it is a possibility of the opti. I don't jump on opti either, but just my opinion from what I feel here.
That bucking or roughness up a expressway speed when high gear is used and where the engine is at low RPM and under load. That just seems to be a key factor. You better believe before I did my first opti I did hours of troubleshooting and looked at everything.
http://www.corvettephotographs.com/c4vettes/codes.htm
If you lose one of the pulses from the optical sensor within the parameters of setting a code, then a code will be set. But many times the cap is bad and that does not set a code.
My car had this exact problem but it was only once the engine warmed up and the ICM was heat soaked. OP, does your engine suffer this symptom when cold or only up to temp?
