PCV routing, need help
Old Mar 22, 2014 | 10:25 PM
jv9999's Avatar
jv9999
Default PCV routing, need help
When I bought my '87 someone else has already taken the intake apart. Now that I've fixed the engine (spin bearing), I'm trying to figure out the PCV routing. What I have is a couple of aluminum pipes, some elbows, and other pieces of tubing. If someone has a picture of how the PCV and the vent in the other valve cover are connected, that would be great.
Thanks!
Old Mar 22, 2014 | 11:24 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Here is a stock L98 Corvette Challenge motor that is displayed at Mid America:
Old Mar 22, 2014 | 11:55 PM
MrWillys's Avatar
MrWillys
The picture Ron shows is the PCV valve vacuum side. The supply goes from the throttlebody to the valve cover on the passenger side.
Old Mar 23, 2014 | 12:21 AM
leesvet's Avatar
leesvet
The driver side has the PC Valve itself, with hose running over the valve cover to a pipe that's run along the cover inside edge to a rubber coupler to a nipple in the intake. About middle on intake...
the passenger side is straight forward, BUT, there is a 2nd fitting on the TB that has hose running under the plenum (I rerouted mine to go to fan shroud and over) to the charcoal can and its maze of plumbing.
You should buy the FSM to see ALL the vac lines and all the misc wiring and hoses and how/where they run. Next will be the vac check valve behind the dist that feeds the AIR system, cruise and cabin feed line.
Old Mar 23, 2014 | 04:25 AM
Cliff Harris's Avatar
Cliff Harris
My '86 has this setup (I believe '87 is similar):
The PCV valve has a short hose that connects to the aluminum tube. The aluminum tube attaches to a hose barb on the intake manifold with 7/16" ID rubber tubing.
Old Mar 23, 2014 | 10:29 AM
jv9999's Avatar
jv9999
Thanks guys, the pictures help a lot. I have the FSM, but it doesn't show that level of detail.
Old Mar 23, 2014 | 01:46 PM
leesvet's Avatar
leesvet
Yeah Cliff, that's pretty much what the 87 is.
I remodeled the intake clutter on mine and ran the 3rd hose from the TPS side of the TB, over to the frame along the a/c lines, then secured it to the cross member by the fan motor over to the charcoal canister...Much better with less junk stuffed under the TB and plenum. Also moved the EGR solenoid to the backside of the AIR pump so the vac hose could be accessed anytime for testing the EGR.
To PCV routing, need help
