Hey Scorp508---------alternator/hooker header bracket bolt
Old Jul 17, 2002 | 12:28 AM
scorp508's Avatar
scorp508
Haven't touched them. What bracket is that? I want it. :)
Old Jul 17, 2002 | 12:39 AM
scorp508's Avatar
scorp508
Default Re: (tntcorvette)
its the stock rear alternator/cylinder head brace. Mabey im wrong here but I recall you having an issue with this bracket fitting with your hooker headers.
Mine did not connect there. Mine went to the rear bolt on cylinder #1. Hmm..... :confused:
Old Jul 17, 2002 | 01:02 AM
h rocks's Avatar
h rocks
Scorp has an '87 if I'm not mistaken. My '90 has the brace you speak of.
Old Jul 17, 2002 | 06:43 AM
tommelton's Avatar
tommelton
My 86 has the short one to number one rear bolt, like Scorp...
And it fits with TPIS headers...
-Tom
Old Jul 17, 2002 | 09:09 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: (tommelton)
Mine had a brace like that one shown. Not real sure exactly where it connected to. I had a problem with it connecting to the header and I left it off. Haven't had any problems so far.
Probably should remount it. Just have bigger issues now.
Old Jul 17, 2002 | 09:31 AM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: (scorp508)
Actually I think my 89 had the same bracket like scorps.. I will have to check at home
Old Jul 17, 2002 | 09:40 AM
SloRvette's Avatar
SloRvette
Cruise-In VII Veteran
Default Re: Hey Scorp508---------alternator/hooker header bracket bolt (tntcorvette)
My '90 had the same bracket that Scorp's been talking about. It goes from the alternator to the rear bolt of the #1 flange. No freakin' way it'll work with the Hooker headers.
I made a bracket similar to that one.
Old Jul 17, 2002 | 09:42 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: Hey Scorp508---------alternator/hooker header bracket bolt (SloRvette)
Must be why I left it off! :lol:
Old Jul 17, 2002 | 09:00 PM
cshuman's Avatar
cshuman
I didn't even try to put mine on when I installed my pump ele. because I had seen Scorps post about it not fitting. I just went out to check mine and just installed it after a little adjustment. It fit back into the stock location, the #1 header rear stud and the alternator
Old Jul 17, 2002 | 09:33 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Default Re: Hey Scorp508---------alternator/hooker header bracket bolt (cshuman)
I have the shorter bracket that goes to the number 1 port as well on my 86.It doesnt look like the one TnT has or the photo above.
Also,mine fit fine with the air pump eliminator in its stock location.No problems there.
Maybe GM did change the brackets between years and maybe if some other 85 owners can chime in and let us know,thatd be cool for info.
GM has always changed stuff here and there.Also,is it possible there was a campaign during 85 or so to add those braces to stop vibrations and then for the following year,GM made different ones and began using them on the assembly line?
I thought I read something about this some time back.Also wonder if Z51 cars had different engine braces then standard suspension cars?
Just a few thoughts.
Old Jul 17, 2002 | 09:48 PM
snydcat's Avatar
snydcat
Default Re: Hey Scorp508---------alternator/hooker header bracket bolt (Bill's86Coupe)
On my 85 the bracket is hooked up just like the picture above :yesnod:
Rich
Old Jul 18, 2002 | 01:22 AM
drive it's Avatar
drive it
Sure it'll fit- I just got out a torch, vise and a hammer...... :lol:
Old Jul 18, 2002 | 10:08 AM
SloRvette's Avatar
SloRvette
Default Re: Hey Scorp508---------alternator/hooker header bracket bolt (drive it)
:lol:
To Hey Scorp508---------alternator/hooker header bracket bolt
