Soft pedal after upgrade
Old Mar 23, 2014 | 04:40 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Default Soft pedal after upgrade
Ok guys & gals finished up my J55 upgrade and have a softer pedal than before. Had a hard pedal before which may have been too stiff but it stopped great. What was done-- j55 calipers, carbotech ax6 pads front and rear and bled all 4 brakes until I had a complete fluid change. It stops fantastic but the pedal is much easier to push and grabs lower. Thank's all
Old Mar 24, 2014 | 06:34 AM
blackozvet's Avatar
blackozvet
What is the difference in the caliper piston size ?
If you have larger diameter caliper pistons you have to move more brake fluid.
have a read of this,
http://www.cheapsportscar.net/hydraulics.php
Old Mar 24, 2014 | 08:38 AM
kimmer's Avatar
kimmer
Thank's mate, very interesting and may explain my pedal pressure change but still would like to stiffen it up a bit.
Old Mar 24, 2014 | 09:22 AM
c4cruiser's Avatar
c4cruiser
Not sure about the differences in the J55 caliper and the C5 caliper in terms of piston volume, but when I put C5 front brakes on my '87, I didn't see much of a difference at all with pedal pressure or pedal travel.
What I did do was to install the Doug Rippie brake bias spring in the master cylinder.
Could there be a difference in the master cylinder itself between the stock brakes and the J55?
Old Mar 30, 2014 | 03:28 PM
kimmer's Avatar
kimmer
Default Udate
Ok my neighbor is a young guy and a rookie mechanic so first I'll say letting him work on the car was my mistake. I had the j55 upgrade about done when I needed to make an errand, my neighbor [lets call him ted] asked if he could finish up by putting on the calipers and bleeding them[ have speed bleeders] so ok go for it. I finally got a chance to check things out and re bleed the system when I found the problem instantly. Now I could tell you or make it a little fun so fun it is. What was the problem? Btw the system works like a charm but now I need to chase down why my shift lights not working.
Old Mar 30, 2014 | 03:39 PM
bassackwards's Avatar
bassackwards
I love my upgrade!
My rust resistant rotors already have rust though
Old Mar 30, 2014 | 04:28 PM
ANTI VENOM's Avatar
ANTI VENOM
I'll play your game....Calipers were upside down? Wrong side to?
Old Mar 30, 2014 | 05:17 PM
kimmer's Avatar
kimmer
Bingo! Can't believe he did it.
Old Mar 30, 2014 | 05:34 PM
ANTI VENOM's Avatar
ANTI VENOM
Old Mar 30, 2014 | 07:37 PM
93Rubie's Avatar
93Rubie
NOT THE FIRST TIME I'VE HEARD OF THIS HAPPENING!!! Glad you found it. IDK, how people can do that?
Old Mar 30, 2014 | 08:01 PM
l98tpi's Avatar
l98tpi
Max G’s
My pedal is very easy to push, but I contribute that to the high vacuum and a good booster.
I guess the only benefit to the calipers on the wrong side would be the bleeding would be relatively easy. That makes the bleeder point to the ground correct?
Old Mar 30, 2014 | 08:03 PM
bassackwards
With the bleeders pointing up the air naturally moves toward the bleeder. They nearly bleed themselves. The rears require about 200 cycles.
Old Mar 30, 2014 | 08:19 PM
kimmer's Avatar
kimmer
With the bleeders facing down you can never get all the air out thus soft low catching pedal which you can always pump to stiffen. My pedal is better now than it has ever been.
Old Mar 30, 2014 | 09:04 PM
pcolt94's Avatar
pcolt94
I have seen a post or two also like that.
Kimmer;
The J55 calipers have the same pistons and rebuild kit as the 12" original system. They use the same size pads also.
Did you know there is a left and right rotor. They are directional. Why, the fins are curved for airflow for better cooling.
I like my J55s also.
The rotor is bigger and so is the price.
To Soft pedal after upgrade
