Need a BIN
Old Mar 24, 2014 | 12:59 AM
1987 C-4 Corvette's Avatar
1987 C-4 Corvette
Default Need a BIN
Does anyone have a BIN you could send me for my 1987 C-4? Here's what's done to it, Hedman Street Hedders 68440, 2-1/2" SS Pypes Race Pro Dual Exhaust Systems SCC40R, all pollution crap removed, A/C removed and NOS (wet system). I need a starting point. I have a Moates order on it's way (GM Adapter with chip, ALDU1 and CABL1, BURN2 Chip Programmer, TunerPro RT V5, Ostrich 2.0). Thanks
Old Mar 24, 2014 | 06:32 AM
cohocarl's Avatar
cohocarl
Originally Posted by 1987 C-4 Corvette
Does anyone have a BIN you could send me...
OK, I'll bite...What's a BIN? Maybe I've been spending too much time on Ebay, but the only thing that pops into my head is "Buy It Now".
Old Mar 24, 2014 | 06:52 AM
Joe C's Avatar
Joe C
- I wanted to know, but I was afraid to ask... -
based on this -
- my best guess is it's some sort of programming thing -
Old Mar 24, 2014 | 07:11 AM
cohocarl's Avatar
cohocarl
Originally Posted by Joe C
based on this - - my best guess is it's some sort of programming thing -
From BINary -- A name for directories that contain files stored in binary format -- computer-readable but not human-readable files.
AAAhhhhh....
Old Mar 24, 2014 | 07:28 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
BIN is the "tuning" file that gets burned onto his chip.
Old Mar 24, 2014 | 07:41 AM
JackDidley's Avatar
JackDidley
Start with an ARAP bin and a 6E definition file. You can download them off the net. This will eliminate the need for the cold start injector.
Old Mar 24, 2014 | 07:42 AM
JackDidley's Avatar
JackDidley
bin, is short for binary.
Old Mar 24, 2014 | 08:07 AM
Joe C's Avatar
Joe C
(or 0100100100100000010000010100011101010010 01000101010001010000110100001010)
Old Mar 24, 2014 | 09:00 AM
MrWillys's Avatar
MrWillys
What if it's a manual trans? I'd use AYPY if it is, but without knowing you can't help the OP.
Old Mar 24, 2014 | 12:40 PM
JackDidley's Avatar
JackDidley
Good point on the trans. I didnt know ARAP will not work with a stick. There is a flag for manual there.
Old Mar 24, 2014 | 12:48 PM
tunedport85inject's Avatar
tunedport85inject
here your Gral...
register here and you have access to ALL GM BIN and Definition file for Tunerpro,obviously you have to choose
#1227165 ECM and model year-auto-manual,and final ratio(2.59-3.07...)
http://www.gearhead-efi.com/Fuel-Inj...ams-Tuner-Info!
only stock .bin here (some minor modd or extended rpm version),if you'r asking a base/starting (modified .bin) for your modded engine this is another thing...
Old Mar 24, 2014 | 04:52 PM
MrWillys's Avatar
MrWillys
Jack, Off the top of my head the spark, idle, and TPS tables are different just to name a few. Idle alone is 150 RPM higher in a manual file. The ARAP file would run in a manual, but not as good as a APYP would.
Scott
Old Mar 24, 2014 | 06:03 PM
JackDidley's Avatar
JackDidley
Scott
I am sure you are correct. My bin started out as ARAP, but its so different now I dont know why I even think of it as being ARAP.
Old Mar 24, 2014 | 06:23 PM
samsonb's Avatar
samsonb
Do you have the 87 Prom? I believe you can download the Bin off of your factory prom. Then make changes and burn a new chip.
Old Mar 24, 2014 | 07:25 PM
1987 C-4 Corvette
Jack, Do you have the current BIN you're running now? If so, can you send me the info.? I'd like to get a copy of someone who's running headers and 2-1/2" pipes. I'll deal with the NOS at the track. My understanding is the transmission doesn't make a difference except for the idol (I have an auto).
Old Mar 24, 2014 | 08:11 PM
gerardvg's Avatar
gerardvg
Hi
Should have posted this question in the C4 scan and tune section.
The tunerpro website has all what you need, has been some time since i was playing around with tuning my 85 with tunerpro.
I believe you need the 32B.xdf and the datastream definition, see the link below.
Save everything on your standard chip, always have a spare or back up
You can get yourself into heaps of trouble but look in the C4scan and tune section before you get started.
enjoy
http://www.tunerpro.net/downloadBinDefs.htm
Old Mar 24, 2014 | 09:10 PM
MrWillys's Avatar
MrWillys
Idol is a tv show.
If you compare the manual to the auto file there's quite a few tables that are different including the idle table. Spark tables are quite different also as are at least 5 other tables.
Here's a stock 89 file.
http://www.scotthansen.net/ARAR4198.bin
Right click and choose save target as
To Need a BIN
Old Mar 24, 2014 | 09:58 PM
JackDidley's Avatar
JackDidley
You would do better with another bin. Mr ****** suggestion should work. http://www.scotthansen.net/ARAR4198.bin
When you spray it, you need to reduce timing at least 2 degrees. My race bin has the idle at 1000 rpm so when I stage up, I dont have to feather the gas pedal. I like to stage aat the same rpm each run.
Old Mar 25, 2014 | 04:19 PM
1987 C-4 Corvette
Thanks for all the info. and wish me luck. I'll try working it this weekend if the weather let's me.
Old Mar 25, 2014 | 05:37 PM
samsonb's Avatar
samsonb
I believe this is what you need to download the Bin in your Memcal. That way you know it is exact.
http://www.moates.net/hdr1-memcal-he....html?cPath=64
