327 ci lt1
I remember once back in high school, a friend had a 283 Chevy II with a nice set of heads and a big stick.....ran OK......transferred the same heads and cam to a 350 block.........BIG DIFFERENCE....car was WAY faster.....went from a 14.5 1/4 mile to high 13's....didn't rev as high but sure it sure made MORE HP AND TORQUE
whatever, I am not going to debate your thoughts here.....you like smaller cubes.......no problem, I respect your opinion......
You comparison of a 283 to a 302 would be like saying a 305 is the same as a 350. The 302 produced pk hp at 6800 which is the highest for any factory produced SBC. It is always safer to go with a longer stroke on a street engine for power and longevity. The ultimate is different. The premise of the long stroke argument would have everyone building 434's. Therefore, anything less isn't any good?
I bet I make plenty more power with my longer stroke 350 at 6,000 RPM than your 302 at 6800 RPM; mine has roughly at 350rwhp @ 6000 RPM; see what the 302's did at the wheels (at 6800RPM)......but I am sure you have ways of defying history, logic, and physics on my "improper assessment" of that as well.........
again, no problem with your ideas here....destroke and make more power.......
Currently my L98 is in a 2800 Jeep. 72 010 4 bolt block, 1053 3.48 GM performance parts crank with ZZ4 113 heads and TPI with gobs of low end that can bust anything in the drivetrain.
20 years ago I had a 327 with BowTie heads and a comp 294 solid in the same Jeep. It was waaay faster, but really wasn't what was needed except maybe sand. There's a design for every purpose, and longer stroke is not the only answer end all of said subject.
If the OP wants to put a smaller crank in a LT1 I say go for it, and support it. Presenting a tone that the OP is just a stupid idiot, and longer is the only way makes you wonder who the idiot really is.
Doesn't matter anyway; different heads, etc. The 327 wasn't "waaaay faster" b/c is was a "magical, short stroke 327". If it was in fact faster, it was so, b/c if H/C Intake.
Waaaaaaaaaaay back at the beginning of this retarded thread, the OP asked;
But he should have never asked the question in the first place b/c if that is the reason why he wants to do it (emotional/psychological), then it really doesn't matter what the facts are, if it's a good idea or not! He wants to do it...so go do it! Then report back about your 250 RWHP LT327.
Why do you think Dodge doesn't just put a smaller version of the Hemi in the SRT Viper, instead of lugging that massive V10 around that's so choked down with air restrictors.
BTW; Ford's modular motors (the 4.6 litre) are not over squared, the actually have a longer stroke than bore and are very efficient with the SVT dual overhead cam, supercharged version.....my brother has an 03 Cobra that unfortunately I know a little too well.....
I'll have to let my brother know that his 460rwhp Cobra that has 70K of tough miles (with absolutely no engine problems at all) that the pistons are destroyed from side scuffing.....or maybe they will be........his stroke is too long, right???? OK
It's amazing what I have learned here...........
I need to call my engine builder......see if they make a shorter stroke crank for my 355...may not get it down to 327 but maybe 330 cubes....much better off that way.....I'll have a real screamer.......and I don't want destroyed pistons either......
usually don't post on threads that are somewhat humorous like this since I fear a troll in the mix, but I was rather amazed and could not help myself.....
(says this as I'm eyeballing a 400 to stuff in my C4)
Parts for parts, you won't find ANY 327 that makes the same power as a 350. Not in anything under 7,000 rpm at any rate.
Slap some AFR heads on a 327 with a cam. Go do a pull. Now put those heads and cam on a 350. Guess who wins. It's not the 327.
Why in the hell would you go SMALLER on an engine? (especially if you aren't changing Packaging Size)
For the money you will spend on turning an LT1 into a 327, you could have gone up to a 383, produce MORE power and torque than the 350 (which the 327 will at best EQUAL, part for part), and had enough money left over to buy a cheap turbo kit an go even faster. And I don't know about anyone else, but the rumble of a 383 plus the sound of a turbo sounds like a much more bad *** car than some high revving 327 ever will. And it'd be a hell of alot faster too.
Something else to note, with a 327 build you WILL have to go to a solid roller camshaft or break the bank for a 4 pattern cam, unless you enjoy picking up pieces of engines up off the road behind your car. So you lose reliability, or gain a huge expense in the engine build which would have been completely unnecessary to make MORE power SOONER with a 383.
Someone else here built one a year or two ago same thoughts. Built it with a mild hyd roller nothing special heads. Ran 13 somethings he was bummed but got his 302.
If youre going to do it throw a good 12:1 at it a solid roller thats no good below 4k, a 4.56 gear and a 195 comp port head then youll reap the benefit
