85 throttle body
Old Mar 27, 2014 | 11:25 AM
dms0309's Avatar
dms0309
Default 85 throttle body
Where do you set the idle set screw to, what do you use as a reference, should the throttle plates be closed after setting. I thought the ECM sets the idle anyway so I'm not sure what's the purpose of setting this up.
Old Mar 27, 2014 | 11:33 AM
joe paco's Avatar
joe paco
don't adjust that screw and you will be way ahead of the game! if it's already been adjusted, it will have to be adjusted by a procedure which I do not have at the moment.
Old Mar 27, 2014 | 12:30 PM
dms0309's Avatar
dms0309
Installed a new throttle body, set up the TPS, IAC, and the car was just barely idling when cold so I did try adjusting the screw, it seemed to help a little but I'm not sure it's set right.
Old Mar 27, 2014 | 03:12 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://forums.corvetteforum.com/1570563689-post1.html
To 85 throttle body
