Wire problem?
Old Mar 27, 2014 | 04:02 PM
Dt86's Avatar
Dt86
Default Wire problem?
I replaced the passenger door lamp with a new one. It is only working when pushed on and not when the door is opened. The rest of the interior lights do come on when the door is opened. I obviously have power to it and the jamb switch is operating. Any ideas?
Old Mar 27, 2014 | 07:20 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I would be looking/testing the switch contacts and check to see if there is ground present at white wire with door open.
Old Mar 27, 2014 | 07:23 PM
Dt86's Avatar
Dt86
Thank you! I will check that. Is it supposed to ground on the door or somewhere else?
Old Mar 28, 2014 | 07:36 AM
AGENT 86's Avatar
AGENT 86
The white wire gets ground from courtesy light timer.
To Wire problem?
