performance modules
Old Mar 29, 2014 | 12:41 PM
BIGMARK1954's Avatar
BIGMARK1954
1st Gear
Default performance modules
I picked up a 1994 corvette base model with automatic tranny and have a few questions????
After installing a cold air intake, and magnaflow exhaust....I now want to do a performance module. From my research, it seems like the Jet Performance Module would be an easy plug and play add on to gain about 25HP.
I would appreciate any advice on performance modules for a C-4, has anyone used the Jet PM?
THANKS
Old Mar 29, 2014 | 12:55 PM
John A. Marker's Avatar
John A. Marker
Save your money. Your not going to get 25 HP with the module. Your computer can handle the changes you have made without any problem. Spend your money on 1.6 RR ans new valve springs.
Old Mar 29, 2014 | 01:01 PM
c4cruiser's Avatar
c4cruiser
It will NOT provide any reasonable HP gains. Certainly not 25HP That's simply marketing BS.
Real HP gains at this point will come from internal engine work, a good performance tune in the ECM, and a set of headers.
One problem you may deal with is whether or not engine mods will cause problems if the car has to go thru emissions testing.
To performance modules
