Wheel bearings?
Old Jul 17, 2002 | 02:58 PM
edsalinas's Avatar
edsalinas
St. Jude Contributor
Default Wheel bearings?
There was a post a few weeks back regarding a source for wheel bearings. I didn't write the info down. Can someone help me out here ? ?
Thanks....... :crazy: :smash: :crazy: :smash: :crazy: :smash:
Old Jul 17, 2002 | 03:04 PM
scorp508's Avatar
scorp508
Front or rear? I get my rear at Pepboys for $139.99 with lifetime warranty.
Old Jul 17, 2002 | 03:07 PM
edsalinas's Avatar
edsalinas
Default Re: (scorp508)
Thanks Scorp, looking for both, front & rear, '84 & '92. Friends are looking also for '85 f/r. We just need sources. What year from Pepboys @ $139.99 ? ?
Old Jul 17, 2002 | 03:10 PM
scorp508's Avatar
scorp508
I believe all C4s have the same unit.
Old Jul 17, 2002 | 04:31 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Wheel bearings? (edsalinas)
I would be interested in finding a good source for the front one as well for the '92-96 with the built in speed sensor that you can not replace seperately. Best price I have seen is TLD and they still want $225 for it. I have checked with Jeff too (usually the first stop), but his price is higher than TLD for a change.
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Default Re: Wheel bearings? (Vette92)
I replaced my rear one with the one from Pep Boys too. Should be the same for all years like Scorp said.
Old Jul 17, 2002 | 04:45 PM
edsalinas's Avatar
edsalinas
Perhaps it's the hubs that are different part numbers ? ?
Old Jul 17, 2002 | 04:49 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
The hub and bearing is a complete unit for the rears. Pep Boys will actually call the assembly a "hub" assembly.
Old Jul 17, 2002 | 04:58 PM
edsalinas's Avatar
edsalinas
So you're saying that the rear hub assy is the same part number for all c4's & they come with the bearing ?
Old Jul 17, 2002 | 05:03 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
That is correct. Just make sure your definition of hub is that same as what they call the hub assembly. I have one on the bench at home I can photograph if necessary.
Chris
Old Jul 17, 2002 | 05:04 PM
Rick92's Avatar
Rick92
I ordered oem delco's from the forum mall for 217.55 each for fronts with sensor for a 92. The part was from zip that was 2 weeks ago :cheers:
Old Jul 17, 2002 | 05:12 PM
edsalinas's Avatar
edsalinas
Chris
That would be great. Can you e-mail it to me cecenaad@flash.net
Many thanks, Eddie :yesnod: :yesnod: :yesnod: :yesnod: :yesnod: :yesnod:
Old Jul 17, 2002 | 08:06 PM
ered95's Avatar
ered95
There was a thread about using front hubs off a 94 Firebird. Other than the threaded flange, they are the same as a Vette hub but about one half the cost. They even have the speed sensor. O`reilly has them for about $106 and Autozone for about $125. Worth checking out. :cheers:
Old Jul 17, 2002 | 08:19 PM
90pololt4's Avatar
90pololt4
I replaced all four from Pep Boys. Fronts= $159 Rears= $139. I had to press in longer studs and all went well. Two auto-x's, one at Wendover on the gripy concrete, and one on asphalt and all is fine. The previous ones lasted two seasons of auto-x and 600 miles of track use with two drivers. They did their job.
Old Jul 17, 2002 | 09:49 PM
olephart's Avatar
olephart
I bought rears (SKF) from Mike Kalin jenavet@earthlink.net for $120. I was very pleased with the product and the service. He wants $199 for the 91-96 fronts.
I used 94 Firebird fronts (for 91-96 vettes with speed sensor) - $109 at Pep Boys. Search for "Firebird Hub" in the title and get the details for using them.
The rears are the same for all C4's.
[Modified by olephart, 7:54 PM 7/17/2002]
[Modified by olephart, 7:56 PM 7/17/2002]
Old Jul 17, 2002 | 10:17 PM
edsalinas's Avatar
edsalinas
Default Re: Wheel bearings? (olephart)
The rears are the same for all C4's. . . . .
That's what I was looking for , , , , , , , Thanks very much...... :cheers:
Old Jul 18, 2002 | 08:29 AM
PTz-92-LT1's Avatar
PTz-92-LT1
Autozone has NDH (OEM) bearings packed in Timmken box: Rear 513020 $157.99, Front (with sensor) 513085 $150.99. Don't ask me why the fronts are cheaper.
To Wheel bearings?
Old Jul 18, 2002 | 12:45 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Default Re: Wheel bearings? (PTz-92-LT1)
Looks like I will have to try the Firebird bearing. :D
Thanks for the repost. Saved me some $$$.
Old Jul 18, 2002 | 06:54 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
So Firebird is a Pontiac, right?
Old Jul 18, 2002 | 10:03 PM
emoshn's Avatar
emoshn
So, where does one order the firebird bearings?
