T56 crossmember
Old Mar 31, 2014 | 09:25 PM
Austvet's Avatar
Austvet
Default T56 crossmember
Hi all. I am replacing the 4 x 3 in my 84 C4 with a tremac T56. Looking for a gearbox crossmember. Does anyone know of anybody doing one to suit? Thanks.
Old Mar 31, 2014 | 09:34 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Most people fab up a bracket that allows the retention of the C-beam, to hold up the transmission.
http://forums.corvetteforum.com/1578080510-post13.html
Old Mar 31, 2014 | 09:39 PM
DHobbs's Avatar
DHobbs
prostreetcustoms.net used to make adapters for them and t5s. Haven't been able to find them lately. Looks like he disappeared
Old Mar 31, 2014 | 10:29 PM
Austvet's Avatar
Austvet
Ok thanks. Looking for cheaper alternative 1 st.
Old Mar 31, 2014 | 10:32 PM
Austvet's Avatar
Austvet
Thanks. Thought someone there would have an over counter one.
Old Mar 31, 2014 | 10:49 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Cheaper than fabbing your own??
But you want an over the counter one?
Old Mar 31, 2014 | 11:07 PM
Austvet's Avatar
Austvet
When the mech workshop is charging around $75 per hr than yes an over the counter one at about $300 landed here is still going to be cheaper than me paying for materials on top of an hourly rate to produce one.
Old Apr 1, 2014 | 05:24 AM
WVZR-1's Avatar
WVZR-1
There's no less expensive alternative than the mentioned here:
There's two images in that thread and if both transmission are on the bench you just fabricate and modify the bracket to your preferences using similar thickness wood** product and glue. When you've a suitable "model" you have it duplicated in the appropriate material. Better than using the 4+ put your hands on an A4 extension. Your only other requirement is the C-beam you intend to use.
You'll be only limited by your own capabilities. When completed yours should fit, some "over the counter" didn't do very well.
I did a "Google" search and ended up with several images that could help.
** I've done similar projects but used plastic product because it could be threaded and use threaded fasteners.
Old Apr 1, 2014 | 01:33 PM
DanZ51's Avatar
DanZ51
My .02 the ProStreet mount was reasonably cheap and it made my project move forward a little faster. If I had the time I could have made my own. To have something like this fabricated you need to be talking to a welder, rather than a shop mechanic (flat rate=$$$). Even a hobbyist welder could fab one up. Have the "C" beam on hand, as well as the T56 and a lot of pictures: your in business!
Old Apr 2, 2014 | 01:18 AM
Austvet's Avatar
Austvet
Ok. Looks like fabricating one is the only option. Thanks for your feedback though.
To T56 crossmember
