installed new egr valve, and map, air idle control, new fuel pressure regulator. car runs strong and idle stays steady now not surging at lights. and now at wot it just go's and doesn't stumble anymore..
question is when i start the car n let it warm up, the egr doesn't seem to move at all, and check for vacuum at the solenoid only have vacuum at one of the lines is this the way it should be, also theres no code anymore since i replaced the egr..
I'm i just looking for ghost after fixing so many thing to get this car running strong again.
