Retrofitting '88-up A/C Compressor to '84?
Any tips, ideas, etc. are appreciated! Thanks!
I have done this many years ago after going through a couple of the original compressors,
You will need the A/C bracket and the supports.
This is where it gets tricky, only the later years had the 3 supports.
without them the bracket will vibrate and eventually crack.
You will also have to drill and tap the head for one of the bolts and fit a washer if you are using the standard iron heads, aftermarket heads have that already there. put the later model a/c bracket on with the bolts just finger tight and get a center punch to mark the center of where the new thread needs to be then remove the a/c bracket. Carefuly drill only 1/2 an inch into the head, (put some tape on the drill) you do not want to go any further as you may hit the water jacket in the head then tap the hole. (you would then need thread sealer if you did hit the water jacket) See link number 2 the bracket with the extra hole on the top left that the early heads did not have.
you will need the 88-91 compressor bracket, supports and compressor with the refrigerant hoses and bracket. You can get the hoses custom made. (has been around 8 years ago i did it not sure if the hose to condenser needs a different fitting)
http://www.ebay.com/itm/88-91-Corvette-C4-A-C-Bracket-W-Belt-Tensioner-Assembly-PT-10105236-10055897-/121253892413?pt=Motors_Car_Truck_Parts_Accessories&hash=item1c3b4b913d&vxp=mtr
http://www.ebay.com/itm/91-Corvette-AIR-CONDITIONING-BRACKET-w-BELT-TENSIONER-C4-Vette-90-89-88-AC-/221406798761?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ACorvette&hash=item338cdfa3a9&vxp=mtr
http://www.ebay.com/itm/88-91-CORVETTE-C4-AC-A-C-AIR-CONDITIONING-COMPRESSOR-DENSCO-W-CLUTCH-10135688-/190827297712?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c6e317bb0&vxp=mtr
http://www.ebay.com/itm/89-CORVETTE-C4-A-C-AC-AIR-CONDITIONING-COMPRESSOR-HOSE-/190918668174?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c73a3af8e&vxp=mtr
See pic's below, 1 the bracket diagram, 2, 3 and 4 the pics where they bolt to.5 pic of it on the car with the bracket to the no. 4 cylinder exhaust manifold.
I thought getting all the appropriate brackets and miscellaneous pieces would do it, but that seemed like a BIG task.
I was thinking of asking SunCr (our Forum AC expert) about the possibility of doing something like this but I sorta never got around to it...
The '94 through '96 systems have larger evaporators and condensers because they use R-134a, which is less efficient than R-12. If you need to replace one of these components then it would be good to go with the larger version even if you're sticking with R-12.
Last edited by Cliff Harris; Aug 16, 2014 at 11:30 PM. Reason: Corrected years when R-134a was used.
http://www.starkmfg.com/EngineeringR...ion.aspx?id=14
