L98 Distributor
Old Jul 17, 2002 | 08:14 PM
Vettdaddy's Avatar
Vettdaddy
Default L98 Distributor
My engine rebuild revealed a none computer distributor on this car.
Car ran great before rebuilb these guys say can't tune it with this distributor on car .
Any comments, suggestions greatly appreciated.
Old Jul 18, 2002 | 07:26 AM
Rich B.'s Avatar
Rich B.
Default Re: L98 Distributor (Vettdaddy)
OK: I'll take a shot at this...
If it ran great before rebuild, why can't you just re-connect it, set the timing, and drive off?
Old Jul 18, 2002 | 01:38 PM
Vettdaddy's Avatar
Vettdaddy
Default Re: L98 Distributor (Rich B.)
They are telling me they are reading a knock on their diagnostic, service engine light comes on also....
Old Jul 18, 2002 | 01:41 PM
scorp508's Avatar
scorp508
How are they setting the timing?
They must turn the car off, disconnect the EST wire, set the timing, turn the car off, reconnect the tire, turn the car on. The engine light will come on if you do not reconnect the wire.
Old Jul 18, 2002 | 02:11 PM
SloRvette's Avatar
SloRvette
Cruise-In VII Veteran
Just get a distributor from a computer controlled Chevy car or truck. As long as the plug is still there in your harness you shouldn't have a problem.
A small cap HEI distributor should also work. I converted to one because of a SuperRam. The wire colors are the same for both the large cap and the small cap. Pin positions in the plugs are different. You just need to get the distriutor, coil, coil to distributor harness and the plug for the small cap distributor. Any throttle body injected Chevy V-8 will have the parts you need. I paid $50 used.
You trust the shop doing the work ? They should've been able to do what I just told you, or at least located a distributor for you.
[Modified by SloRvette, 6:15 PM 7/18/2002]
Old Jul 18, 2002 | 06:11 PM
Rich B.'s Avatar
Rich B.
Default Re: (scorp508)
...set the timing, turn the car off, reconnect the tire, ...
..."Tire"???...Oh, you mean *wire*!... :D
Disconnecting the battery ground after setting the timing should wipe out the SES light, too.
Did they drive it around a bit? Has the ECM "re-learned" the program? When you did the rebuild, did you do anything that would affect the timing? Like a new high-perf cam, or higher compression, or something like thet thar?
Is the knock sensor OK? They're [comparatively] cheap.
Your description of this shop does not inspire confidence... :nonod:
[Modified by Rich B., 5:12 PM 7/18/2002]
Old Jul 18, 2002 | 06:39 PM
ZylaRace's Avatar
ZylaRace
"can't tune it with this distributor on car."
Shure you can. Using the ECM to tune for spark won't do anything.
None ECM distrib's are tuned w/ springs and adv plates. (The old day's.)
What do you wanna do?.... Go back to the stock distrib? Just get it running?
Old Jul 18, 2002 | 06:48 PM
Sharky Guam's Avatar
Sharky Guam
Default Re: L98 Distributor (ZylaRace)
Why would you want to run an "old school" distributor with a late style setup? I would try to find the correct distributor. But if it ran fine before the rebuild, it should be simple to duplicate. Just follow the procedure that Scorp said. That is except for the tire part
If you do the "tire " thing like Scorp suggested, make sure that your tire is at the right temperature and pressure. The pressure especially affects the timing setting! I thought everbody knew that. Maybe that is why your mechanic cannot set the timing with that distributor. :D :lol: :lol: :lol: :lol: :lol: :lol: :lol:
[Modified by Sharky Guam, 8:49 AM 7/19/2002]
Old Jul 19, 2002 | 12:28 AM
Vettdaddy's Avatar
Vettdaddy
Default Re: L98 Distributor (Sharky Guam)
Thanks all, this car was modified prior to me getting it, I put about 2000 miles on it, lot of road course, spun a rod bearing hence the rebuild.
The shop is a combination of computer wiz kids and an old vet. I don't know why it was changed so am reluctant to change back, it ran strong before it broke (M3 eater). with slicks on it had good speed in corners and lots grunt out of them.
Original owner out of town, so no info there. was set at 32 degrees total. it's had some minor head work, chip, exhaust etc nothing to major, just want it running again.
Thanks again
Cal
To L98 Distributor
