knock (again)
Old Jul 17, 2002 | 10:22 PM
GlockLT4's Avatar
GlockLT4
Default knock (again)
Backgroud: 11.55:1 CR, 2 brand new knock sensors, LT4 knock module.
If there is real knock, the computer should be picking it up, right? I don't care about flase knock as long as it's at least picking up real knock.
Old Jul 18, 2002 | 01:32 AM
devons88vette's Avatar
devons88vette
Default Re: knock (Glock'94)
I'm having a knock problem also. Nothing seems to correct it.
Old Jul 18, 2002 | 01:37 AM
GlockLT4's Avatar
GlockLT4
Default Re: knock (devons88vette)
i'm not really sure i have a problem.. i tried to get some race gas today to see if it goes away, but they were all out! :eek: :nonod:
I'm getting knock counts sometimes, but not when I hear a mettalic rattling noise, which i'm wondering if it isn't real knock the computer isn't picking up.
Old Jul 18, 2002 | 01:41 AM
devons88vette
mine makes a metallic rattling noise under light acceleration. Is this considered knock? How do I correct it? I have switched gas.
Old Jul 18, 2002 | 01:43 AM
GlockLT4's Avatar
GlockLT4
I don't know. That's what i'm trying to figure out with mine. It's either something like the cover to the flexplate/torque converter rattling at a certain harmonic, or it's donation.
Mine is around 3500rpm
Old Jul 18, 2002 | 01:53 AM
rguy's Avatar
rguy
do you have Diacom or Autotap?
Old Jul 18, 2002 | 01:55 AM
GlockLT4's Avatar
GlockLT4
Default Re: knock (rguy)
I use Datamaster
Old Jul 18, 2002 | 01:59 AM
rguy's Avatar
rguy
Is it picking up knock on the Datamaster, or are you hearing or feeling it?
Old Jul 18, 2002 | 02:03 AM
GlockLT4's Avatar
GlockLT4
I hear a metallic rattle at 3500-4000 ... which datamaster doesn't pick up as knock.
It picks up knock at other times when i don't hear anything.
Old Jul 18, 2002 | 02:38 AM
rguy's Avatar
rguy
i would guess it's false knock since it's isolated, it's so low in the power band, and you're not making a shift... but it just a guess. I'd ad a similar problem once my '93 TA. The motor mounts had deteriorated and let the engine drop. The headers hit the frame/body and the KS was picking it up.
If the datamaster isn't picking up knock through the sensors, then I wouldn't think you have knock. Does the engine feel like it's loosing power at that point or do you jnut notice the sound?
Sorry I can't lend any useful advise.
Old Jul 18, 2002 | 02:42 AM
GlockLT4's Avatar
GlockLT4
oh, any advice is great :)
I don't feel loss of power when i hear the metallic rattle. The reason for wanting to get race gas is so i can be sure it's not knock. It'll also allow me to see if the knock datamaster IS picking up is false or not.
Old Jul 18, 2002 | 08:35 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Glock,
Hey guy. You should NEVER really hear the knock. The sensor should pull the timing back before it ever becomes audible. Now if the knock is so bad that it exceed the parameters of max pull out then you will hear it.
Sounds to me that something is just rattling. I would try to find out what it is. Not sure on your car, but there are several heat shields on the L98s that could make the noise you describe. If the knock sensor is not pulling time at that point, then it is not knock.
How is the overall picture looking for your tuning. Get the BLMs straight and most of the knock out?
Let me know.
Old Jul 18, 2002 | 11:53 AM
GlockLT4's Avatar
GlockLT4
Default Re: knock (ski_dwn_it)
ski,
yes, it seems to be running very well besides that odd noise. I still haven't completely figured out why I'm getting a little knock. But, like I said, when I get some race gas I'll find out if that's false knock or something I need to work on. You've been a great help ski, thanks! Tuning is a never ending venture with these cars the second you start modifying them. :crazy:
Old Jul 18, 2002 | 01:23 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
ski,
Boy isn't that the truth!
I would se if the car make the *noise* while sitting still and at that RPM. If so then you can put it up on a lift or secure it VERY good on jacks, etc and crawl under it and have a buddy rev it so you can see it. Or better yet, if you have friends like mine, send one of them under to look :lol:
My dust cover for the TC had a bolt or two stripped on it, so I just deleted it. It really serves no purpose. I just have to be careful when I have it on a lift and the engine is running. That flywheel could do some serious damage to the scalp! :eek:
Check all the heat shields too.
Do you have headers?
Old Jul 18, 2002 | 01:27 PM
GlockLT4's Avatar
GlockLT4
yeah, i'm still thinking it's the dust cover .. because that's around where the noise is... and i can hear a little bit of a buzz when sitting still and revving it.
no header, just stock manifolds right now.
yeah, i'll check my heatshields.
Old Jul 18, 2002 | 01:38 PM
C4-Wolf's Avatar
C4-Wolf
The dust cover on my 4+3 was doing the same thing. I guess if it were more subtle it could have sounded like detonation. It happenned at the same rpm every time. Good luck Glock.
Old Jul 18, 2002 | 01:41 PM
GlockLT4's Avatar
GlockLT4
Default Re: knock (C4-Wolf)
ok, i'll definitely check into it then, thanks :cheers:
To knock (again)
Old Jul 18, 2002 | 03:16 PM
rguy's Avatar
rguy
stock manifolds on a 383???
Old Jul 18, 2002 | 03:26 PM
GlockLT4's Avatar
GlockLT4
yeah, college budget, ran out of $ for the car, so headers is one of my next upgrades.. after I put cats back on.
Old Jul 18, 2002 | 04:36 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
One other thing glock. Check to make sure the precats are not falling apart. They can make some silly noises too.
