Distributor and Superram
Old Apr 6, 2014 | 10:38 PM
PMARTINEZ92126's Avatar
PMARTINEZ92126
Default Distributor and Superram
Does anyone with a Super ram intake have issues trying to get the distributor to line up with the number one sparkplug terminal. I can get it close but When I turn it the distributor butts up against the super ram when I try to turn it to get the timing right. Im sure its just me but anyone have any idea on installing it so I have a little wiggle room. I have number one spark plug in the usually place. I hope I explained this correctly.
Old Apr 6, 2014 | 11:21 PM
cumbercr's Avatar
cumbercr
If it hits the SR plenum then back the distributor up one tooth. On mine the #1 spark plug wire just fits between the cap and the plenum.
Old Apr 7, 2014 | 01:12 AM
383vett's Avatar
383vett
Old Apr 7, 2014 | 02:14 AM
MrWillys's Avatar
MrWillys
To do this you may have to turn the oil pump shaft with a long screw driver. I use a flashlight so I can see while doing this.
To Distributor and Superram
