brake question
Old Apr 7, 2014 | 11:19 AM
pastamike's Avatar
pastamike
Default brake question
the pin that holds the caliper on is it on the bottom of the caliper or the top when sitting in the bracket..i have seen a post of someone selling the whole front end on here and the pin sits at the bottom of the caliper, that could be why mine are clunking when i brake, i installed them the way they came off, op may have put them on wrong to start..even with two sets of new clips they still make noise..
i take one step forward and 2 back it seems.........
pasta
Old Apr 7, 2014 | 11:52 AM
Joe C's Avatar
Joe C
the pin sits at the bottom of the caliper housing. there should also be a circlip securing the pin in place. if you are getting a clunking noise, it could be that the pins are worn, allowing caliper movement on the mounting bracket. the FSM indicates to install new pins during brake service.
Old Apr 7, 2014 | 02:08 PM
pastamike's Avatar
pastamike
so if I'm reading this right the caliper brackets are on the wrong side of the car, seeing the new pins are on top not the bottom of the caliper correct...
so i need to tear it down and reverse the brackets..
pastamike
Old Apr 7, 2014 | 02:58 PM
Race Prepared's Avatar
Race Prepared
Yes, pins are on the bottom. If your car has the pins installed on the top, that is wrong.
Old Apr 7, 2014 | 03:45 PM
pastamike's Avatar
pastamike
thanks now time to take them apart and make them right..dont know how the first owner got them wrong or the tech that did them last,got the brackets on the wrong sides, plus the c-clips weren't even the same..and missing one washer too. thanks again guys for the help...
glad i took this week off and its my 60th birthday too oh happy me..
pasta mike..
Old Apr 7, 2014 | 03:46 PM
Joe C's Avatar
Joe C
pasta mike..
hey - 60 is only a number - rock on!
Old Apr 7, 2014 | 03:57 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Welcome to the 60 club.
Old Apr 7, 2014 | 06:21 PM
pastamike's Avatar
pastamike
great to be apart of the club, now can i make 70,
To brake question
