L98 Air Flow Help
http://temp.corvetteforum.net/c4/vader86/
Long tube headers knocked almost a second from the quarter mile, they are the best bang for buck.
Adjustable fuel pressure regulator next, 45-50 psi in conjunction with headers really wakes these L98 engines up.
I went from standard 14.4 quarters to 13.6 a week later with long tube headers, next was cold air intake and adjustable fuel pressure regulator set 48 psi , new plugs leads filter and tune got it down to 13.3 in the quarter mile.
That was around ten years ago, now she is blown forced induction is just what these L98 intake system needs to go quicker.
I essentially agree with the mods listed by Vader86. Cheap mods that have worked on my '88:
-remove the "frisbee" from the front of the WP pulley
-cut lid with K&N
-replace the front Y with a 2 1/2" mandrel bent unit and hi-flow main cat
-TB coolant bypass is mostly a convenience for later removing the TB
-bump base timing to around 8 deg BTDC
-advance the TPS to about 0.67 Vdc at base idle or around 0.75Vdc at normal idle
-stock AC Delco spark plugs with base electrodes cut back & dressed
-an AFPR with fuel pressure set to around 48psi
-run 1/4-3/4 tank of fuel; 1/2 tank of fuel ~60lb==6hp gain
-toss the spare & jack; ~40lb==4hp gain
The above should put your '88 well into the mid 13s in the 1/4 mile run.
If you want to increase the SotP fun, install a TransGo shift kit and feel the tail wag on the 1-2 upshift...
Some of the above are free while others are relatively inexpensive and sime are labor intensive (e.g. AFPR installation).
