Need Brake Rotor Help
Old Jul 18, 2002 | 01:04 PM
Guest
Guest
Posts: n/a
Default Need Brake Rotor Help
The stock rotors suck, I know that. But I am on a budget here. Can I turn my rotors if they're warped? Has anyone done this?
Old Jul 18, 2002 | 01:17 PM
Racer1x's Avatar
Racer1x
Default Re: Need Brake Rotor Help (topjimmy87)
You can turn them if they are not to thin,if you get them too thin they just warp easier from the heat. Any shop will measure them, if they are too thin they wont cut em.
Old Jul 18, 2002 | 01:35 PM
92TripleBlack's Avatar
92TripleBlack
Default Re: Need Brake Rotor Help (Racer1x)
If you can't turn yours, check with Jeff Kopp 18carfan and he can get you a good deal.
Old Jul 18, 2002 | 04:04 PM
c4cruiser's Avatar
c4cruiser
Not sure about the thickness of the rotors in early-mid year C4's but for my 92, the service manual says not to turn them. If they are warped, I don't think there is near enough material to correct that. Try an Auotzone or such and get rotors with a lifetime warranty. That way if they wear out early (like right after a track day) just take 'em back and ask for another set!!
Old Jul 19, 2002 | 08:31 AM
gtsyellow's Avatar
gtsyellow
Default Re: Need Brake Rotor Help (c4cruiser)
TPIS has a great deal on drilled plated rotors for the early years $162 per pair.
Old Apr 23, 2024 | 01:53 PM
jsinga's Avatar
jsinga
Don't turn them, they shake again within months.....
Read about where the people who track cars get rotors. If they run stock brakes they throw rotors away all the time.
To Need Brake Rotor Help
