air bag
Old Apr 12, 2014 | 02:38 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Default air bag
Is there anyway to turn off the air bag light without pulling the bulb?
Old Apr 13, 2014 | 04:51 PM
WVZR-1's Avatar
WVZR-1
Yes - you would substitute a 2 Ohm resistor for the air bag at the bottom of the column or you could do it at the top of the column if you planned on leaving the coil in place. 1/4 watt is what is most frequently mentioned. They're not that easily found but a custom audio, seat replacement shop or an air bag repair service should have plenty of them. Needs to be 2 Ohm and not something close.
You didn't mention year but if it's an earlier one it would also put out the seat belt warning in the cluster.
Old Apr 14, 2014 | 08:34 AM
kimmer's Avatar
kimmer
Cool, will do the resistor fix, put on an aftermarket wheel so the coil is out ,thank's.
To air bag
