Chevy ZF1 6 Speed
Be advised that it won't be an easy or inexpensive fix. The gearbox will almost surely have to be removed from the car.
Contact Bill Boudreau (the ZF Doc) at ZR51 Performance about this. He will give you great advice about your options to quiet things down. You can reach him here:
Bill Boudreau
ZR51 Performance
5612 East Almeda Court
Cave Creek, AZ 85331-6405
602-319-6575
Live well,
SJW
Bill Boudreau
ZR51 Performance
602-319-6575
Live well,
SJW
Not sure if its worth the fix in the long run
Appreciate your help though.
If it's bothering you, the only thing you can do is replace the DMF with a new one.
The Al SMF is cool for the occasional "Woomah" and is easier for spirited shifting. It is noticeably more difficult to get the car off the line though.
Are you guys saying the steel single flywheel is a better chioce than aluminum ?
i'm replacing clutch and flywheel this year and trying to decide the best choices !!
The gear rattle is caused by the gear cut in the transmission. The dual mass has a large spring in between the two masses that absorbed much of the back and forth motion of the input shaft and helped to keep the gear noise down. However, it adds a lot of weight to the rotating assembly, which will slow down acceleration response. However, this extra weight does add momentum to the rotating assembly, making it easier for stop and go driving. The lighter wheel tend to need more engine rpm to get going from a stop, since that momentum is not there.
The flywheel dampens the noise.
I got rid of the noise and have the benefits of an aluminu. Flywheel.
You have to remove the trans to instaall zfdocs countershaft shim to trim the transmission.
This made all noises go away, even with my 12 lb flywheel.
I installed the extra-weight billet steel SMF from Spec in my '94, and have almost no added noise from the ZF, as compared to when I still had the OEM DMF in the car. The only time I hear anything is when I'm rolling at very low RPM in the upper gears, with the ragtop and windows up and the stereo off, and even then, it's so slight that I didn't notice it until I'd driven the car for months. Nobody who has ridden in the car has ever commented on it. I'm sure I'm the only person who's ever noticed it. It is very, very faint.
I went with the heavy flywheel because I really did not want a lot of clatter out of the gearbox, and I'm very glad I made that choice. I would make the same decision again without hesitation.
Live well,
SJW
I'm confused , if a lighter flywheel is better for performance and acceleration. How come a heavier one is easy to stop and go !
Live well,
SJW
With the lighter flywheel, it takes more rpm to overcome the still intertia of the driveline, and makes it a little more difficult to make a smooth slow start in traffic.
The lightweight wheel is better in terms of performance for the same reason. It takes away less engergy to get the driveline spinning faster, as in the rear wheels. For example, doing a 40 roll, you will accelerate to 100 much faster. From a standing start, it will a bit more of challenge to prevent wheel spin, but once you do, you'll get up to speed much quicker.
Now it depends on your choice of set up. I have a Spec 22lb flywheel and a Carolina Clutch Stage II disc. So, ahile I need a little more rpm to get the momentum needed, the clutch, while solid, isn't so grabby that I can't slide it enough for a smooth start. I have heard of some going with a higher grip clutch that makes this more difficult. There is also the noise factor. I have an audible gear rattle, for some it would be a real issue. I know what it is, so it doesn't really bother me that much.
Second question. The dual mass weighs in at about 40lbs. Many of the single mass stell wheels are 36-38lbs. When used with a sprung hub clutch, the added mass will help to absorb some of that gear rattle in neutral, and take off. They are not quite as effective as the large spring in the dual mass, but better than the lightweight wheels.
Thanks a lot , that was informative.
I need to make up my mind on which flywheel to get. alu or steel.
What do you suggest ?
My car has boltons and hot cam. 334rwhp/334rwtq.
I think it has a single mass flywheel because I hear little rattle when idling.
it's a weekend car , very few 1/4 runs during the year.
To the OP; if you think you may sell the car someday, I would think about a DM. If you plan on keeping the car for some time and are more into performance than anything else you probably won't have an issue with the SM. Just my .02, hope this helps.
However, if there is a fix for it, and it can be greatly diminished for not alot of money or added work, why not? Now, it wasn't until I had finished my flwheel/clutch swap that I learned about the shim. I don't really want to go back in just for that, but when I do the u-joints here shortly, and I'm a mere 5 bolts from having the trans out, I'll probably do it then.
Now, alos understand that part of this issue is that the DMF is no longer available, at least new by a vendor. Many people would like to keeps that factory spec as much as possible. But when the old DMF goes bad, there's just not alot of options for keeping a quiet transmission.
All the various rods and shafts simply make a lot of noise in there.
the gearbox was altered to lower the gear whine in first and second, not to stop rattles.
The dual mass does nothing to stop gear whine.
Now, the light rapping at neutral/ clutch disengaged (ie. Pedal not depressed) is still there, maybe not as bad.
This shim made a huge difference and again, this is nothing unique to the corvette zf6. Its called trimming the transmission. A buddy had a picture of him, on facebook, doing the same thing on his 03 mustang cobra
as a reminder: blue tag, remanufacured for gm trans with a fidanza 12 lb alum flywheel and spec stage 3+ clutch.
