Harmonic balancer 1986 automatic
Old Apr 14, 2014 | 12:57 AM
PMARTINEZ92126's Avatar
PMARTINEZ92126
Default Harmonic balancer 1986 automatic
can someone recommend a replacement harmonic balancer for my 383 stroker engine. I guess after 25 years it slipped
Old Apr 14, 2014 | 01:45 AM
BOOT77's Avatar
BOOT77
383 external balance?
Old Apr 14, 2014 | 01:49 AM
PMARTINEZ92126
The harmonic balancer with the timing marks that sit behind the crank pulley.
Old Apr 14, 2014 | 05:37 AM
blackozvet's Avatar
blackozvet
I used the Summit balancer, (for external balance 383), its SFI rated for $142,
part number SUM-C4266
Old Apr 14, 2014 | 06:45 AM
vetteoz's Avatar
vetteoz
But as asked above ;
is your stroker crank Int or Ext (400 ci based ) balance ?
Big difference in the balancers
Old Apr 14, 2014 | 11:16 AM
PMARTINEZ92126
I dont think im savy enough to know. I had the machine shop build it years ago. I will see if i can still get ahold of him.
Old Apr 14, 2014 | 11:44 AM
MrWillys's Avatar
MrWillys
Did the crank come from a factory 400? if it's an OEM factory 400 it is externally balanced harmonic balancer. 25 years ago aftermarket cranks were just coming out if I remember right.
Old Apr 14, 2014 | 12:17 PM
PMARTINEZ92126
I was told it was int balanced
Old Apr 14, 2014 | 12:54 PM
MrWillys's Avatar
MrWillys
If you pull the harmonic balancer and inspect the back it will be symmetric if internally balanced, and not if external.
Old Apr 16, 2014 | 12:38 AM
PMARTINEZ92126
also its the stock dampner that originally came with the car. When the engine build was complete he used the same one. It has no weights on it and looks stock. THe guy who told me it was int balanced was the apprentice so I really don't know since the machinist is out of town.
To Harmonic balancer 1986 automatic
