Spark plugs
Old Apr 16, 2014 | 09:33 AM
DanielRicany's Avatar
DanielRicany
Default Spark plugs
Hello, AFR recommends NGK R41 CXLS for racing applications, and different plugs for street applications. I have AFR 195 heads and 10:1 Compression with a Miniram and supporting mods. Would I be okay to use NGK R41 CXLS if I do street/strip?
Thanks!
Old Apr 16, 2014 | 09:53 AM
lt4obsesses's Avatar
lt4obsesses
I don't know the exact answer to your question, but here are a couple of questions I would ask to get the answer you need;
1) What is their definition of a racing application?
Many racing applications are set up to run a 100+ octane race fuel, and tend to run higher compression ratios, unless using forced induction of course. Perhaps these plugs are not designed for the lower 91-93 octanes at the pump? A 10:1 is not radical of a ratio for a SBC.
2) What is special about this plug that it is recommended for racing applications and not for street applications?
The plug may have a different temp range that is suited especially for race engines to prevent spark knock or detonation, which would be really bad in a high rpm, wot situation. However, for street driving, it may not be well suited.
Old Apr 16, 2014 | 10:03 AM
JackDidley's Avatar
JackDidley
Sometimes a racing plug will cause RF noise in your stereo.
Old Apr 16, 2014 | 10:38 AM
DanielRicany
How about NGK BKR5E?
Old Apr 16, 2014 | 11:28 AM
JackDidley's Avatar
JackDidley
Try the NGK site. Race plugs and resistor plugs.
Old Apr 17, 2014 | 03:44 PM
DanielRicany
I used NGK BKR6E.
Originally I wanted to use BKR5E, but I did some reading and opted to go 1 heat range hotter.
I messaged Tony Mamo at AFR about BKR5E and he said he thought it might be too cold for a street car.
I used BKR6E and took it for a ride, no overheating, nice exhaust sound and nothing out of the ordinary so far.
Thanks!
Old Apr 17, 2014 | 03:50 PM
DanielRicany
Whoops. Looks like I actually went one step colder. Oh well, my plugs were a little on the white side anyway. If anything happens I guess I'll just change them again. Other people with AFR heads said they use these plugs.
To Spark plugs
